WowWee CHiP Robot Dog Ear Replacement
  1. WowWee CHiP Robot Dog Ear Replacement, Battery: step 1, image 1 of 1
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Ear Replacement: step 2, image 1 of 2 WowWee CHiP Robot Dog Ear Replacement: step 2, image 2 of 2
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Ear Replacement: step 3, image 1 of 2 WowWee CHiP Robot Dog Ear Replacement: step 3, image 2 of 2
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Ear Replacement: step 4, image 1 of 3 WowWee CHiP Robot Dog Ear Replacement: step 4, image 2 of 3 WowWee CHiP Robot Dog Ear Replacement: step 4, image 3 of 3
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Ear Replacement, Ear: step 5, image 1 of 2 WowWee CHiP Robot Dog Ear Replacement, Ear: step 5, image 2 of 2
    • Remove the 4 Phillips screws shown.
  6. WowWee CHiP Robot Dog Ear Replacement: step 6, image 1 of 3 WowWee CHiP Robot Dog Ear Replacement: step 6, image 2 of 3 WowWee CHiP Robot Dog Ear Replacement: step 6, image 3 of 3
    • Pull up top part of toy and remove the connecting wires.
    • Unscrew the 2 Phillips head screws. CHiP should be viewed as seen in the third picture.
  7. WowWee CHiP Robot Dog Ear Replacement: step 7, image 1 of 3 WowWee CHiP Robot Dog Ear Replacement: step 7, image 2 of 3 WowWee CHiP Robot Dog Ear Replacement: step 7, image 3 of 3
    • Remove the 4 Phillips screws to separate the head from the body.
  8. WowWee CHiP Robot Dog Ear Replacement: step 8, image 1 of 2 WowWee CHiP Robot Dog Ear Replacement: step 8, image 2 of 2
    • Remove the 4 Phillips screws on back of the head, and pull off the casing for the back of the head.
  9. WowWee CHiP Robot Dog Ear Replacement: step 9, image 1 of 3 WowWee CHiP Robot Dog Ear Replacement: step 9, image 2 of 3 WowWee CHiP Robot Dog Ear Replacement: step 9, image 3 of 3
    • Unscrew the screw on the ear with a Phillips screwdriver, and pull off the plastic connector. Remove the ear from head.
One Comment
It’s almost a disassembly, probably quite hard to do. I did disassemble a MiPosaur, but some parts broke off. (!!!)
Michael Deitz - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 1,517
