WowWee CHiP Robot Dog Wheel Replacement
Joseph Dantes
Joseph Dantes and 3 other contributors
Last updated on February 25, 2024
4 minutes
Very easy
Better Introduction
  1. WowWee CHiP Robot Dog Wheel Replacement, Battery: step 1, image 1 of 1
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Wheel Replacement: step 2, image 1 of 2 WowWee CHiP Robot Dog Wheel Replacement: step 2, image 2 of 2
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Wheel Replacement: step 3, image 1 of 2 WowWee CHiP Robot Dog Wheel Replacement: step 3, image 2 of 2
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Wheel Replacement: step 4, image 1 of 3 WowWee CHiP Robot Dog Wheel Replacement: step 4, image 2 of 3 WowWee CHiP Robot Dog Wheel Replacement: step 4, image 3 of 3
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Wheel Replacement, Wheel: step 5, image 1 of 1
    • Locate wheel to replace.
  6. WowWee CHiP Robot Dog Wheel Replacement: step 6, image 1 of 1
    • Twist grey wheel cap in counter-clockwise rotation.
  7. WowWee CHiP Robot Dog Wheel Replacement: step 7, image 1 of 1
    • Pull and remove wheel.
3 other people completed this guide.
3 Comments
Why do you have to disconnect the battery before changing the wheel? Can you not just turn off the power and change it?
shawna_beji - Reply
зачем снимать акб?
замена или снятие колес происходит при простом отключении устройства обычным выключателем.
Руслан Смоленск - Reply
Heads up it is really hard to turn
Mary Pownsu - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 45
All Time: 4,280
