WowWee MiP Robot Speaker Replacement
  1. WowWee MiP Robot  Speaker Replacement, Battery: step 1, image 1 of 2 WowWee MiP Robot  Speaker Replacement, Battery: step 1, image 2 of 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot  Speaker Replacement: step 2, image 1 of 2 WowWee MiP Robot  Speaker Replacement: step 2, image 2 of 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot  Speaker Replacement, Wheel: step 3, image 1 of 2 WowWee MiP Robot  Speaker Replacement, Wheel: step 3, image 2 of 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  4. WowWee MiP Robot  Speaker Replacement: step 4, image 1 of 2 WowWee MiP Robot  Speaker Replacement: step 4, image 2 of 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot  Speaker Replacement: step 5, image 1 of 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot  Speaker Replacement, WowWee MiP Robot Body Disassembly: step 6, image 1 of 2 WowWee MiP Robot  Speaker Replacement, WowWee MiP Robot Body Disassembly: step 6, image 2 of 2
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot  Speaker Replacement: step 7, image 1 of 3 WowWee MiP Robot  Speaker Replacement: step 7, image 2 of 3 WowWee MiP Robot  Speaker Replacement: step 7, image 3 of 3
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot  Speaker Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot  Speaker Replacement, Speaker: step 9, image 1 of 2 WowWee MiP Robot  Speaker Replacement, Speaker: step 9, image 2 of 2
    • Remove the two 7.5 mm Phillips #1 screws holding the speaker bracket in place.
  10. WowWee MiP Robot  Speaker Replacement: step 10, image 1 of 1
    • Remove the plastic bracket covering the speaker.
  11. WowWee MiP Robot  Speaker Replacement: step 11, image 1 of 1
    • Gently remove the speaker from the MiP.
    • During reassembly, be sure to place the speaker in the same position.
Daniel Burkholder
623 Reputation
4 Guides authored
USF Tampa, Team 3-4, Wollert Spring 2016 Member of USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 679
