WowWee MiP Robot Tire Replacement
  1. WowWee MiP Robot Tire Replacement, Wheel: step 1, image 1 of 2 WowWee MiP Robot Tire Replacement, Wheel: step 1, image 2 of 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  2. WowWee MiP Robot Tire Replacement: step 2, image 1 of 2 WowWee MiP Robot Tire Replacement: step 2, image 2 of 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  3. WowWee MiP Robot Tire Replacement: step 3, image 1 of 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  4. WowWee MiP Robot Tire Replacement, Tires: step 4, image 1 of 2 WowWee MiP Robot Tire Replacement, Tires: step 4, image 2 of 2
    • Remove the three 7.7 mm Phillips #1 screws.
  5. WowWee MiP Robot Tire Replacement: step 5, image 1 of 3 WowWee MiP Robot Tire Replacement: step 5, image 2 of 3 WowWee MiP Robot Tire Replacement: step 5, image 3 of 3
    • Separate the rubber tire from the rim.
    • Push the collar out to separate the plastic layers of the wheel.
    • When reassembling, align the groove and the key of the two wheels' halves together.
5 other people completed this guide.
Moira Keahon
257 Reputation
3 Guides authored
One Comment
my MiP has plastic over his wheels
Clarrie O'HARE - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 6,101
