WowWee MiP Robot Wheel Replacement
  1. WowWee MiP Robot Wheel Replacement, Wheel: step 1, image 1 of 2 WowWee MiP Robot Wheel Replacement, Wheel: step 1, image 2 of 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  2. WowWee MiP Robot Wheel Replacement: step 2, image 1 of 2 WowWee MiP Robot Wheel Replacement: step 2, image 2 of 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  3. WowWee MiP Robot Wheel Replacement: step 3, image 1 of 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
Daniel Burkholder
623 Reputation
4 Guides authored
USF Tampa, Team 3-4, Wollert Spring 2016 Member of USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,020
