WowWee Miposaur Wheel Replacement
  1. WowWee Miposaur Wheel Replacement, Wheel: step 1, image 1 of 1
    • Remove the 1.2 mm Phillips screws surrounding the wheel and take off the wheel cover.
  2. WowWee Miposaur Wheel Replacement: step 2, image 1 of 1
    • Remove 1.2 mm Phillips screw from the white plastic piece in the center of the wheel and then remove the wheel entirely.
Samir Himes
126 Reputation
1 Guide authored
UC Davis, Team S4-G3, Lore Fall 2018 Member of UC Davis, Team S4-G3, Lore Fall 2018
UCD-LORE-F18S4G3
3 Members
2 Guides authored
One Comment
This will require a TON of pressure on the screw. I tried it. The wheel is removable even without taking out the screw, since it does not require much force this way, either.
Michael Deitz - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 504
