XQ-673H Power Cord Replacement
  1. XQ-673H Power Cord Replacement, Power Cord: step 1, image 1 of 1
    • Turn the Kitchen Gourmet upside down.
    • Make sure the device is unplugged before continuing.
  2. XQ-673H Power Cord Replacement: step 2, image 1 of 3 XQ-673H Power Cord Replacement: step 2, image 2 of 3 XQ-673H Power Cord Replacement: step 2, image 3 of 3
    • Using a phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
    • Remove the bottom cover.
  3. XQ-673H Power Cord Replacement: step 3, image 1 of 3 XQ-673H Power Cord Replacement: step 3, image 2 of 3 XQ-673H Power Cord Replacement: step 3, image 3 of 3
    • Using a Phillips #1 screwdriver, unscrew the 11mm screws.
    • Remove the plastic bar that is holding the Power Cord down.
  4. XQ-673H Power Cord Replacement: step 4, image 1 of 2 XQ-673H Power Cord Replacement: step 4, image 2 of 2
    • Using scissors, carefully cut the zip tie.
    • Careful not to cut the Power Cord.
  5. XQ-673H Power Cord Replacement: step 5, image 1 of 3 XQ-673H Power Cord Replacement: step 5, image 2 of 3 XQ-673H Power Cord Replacement: step 5, image 3 of 3
    • Using small needle nose pliers, gently squeeze the side so it allows the metal clamp to open up.
    • Gently pull off the plastic cover.
    • Repeat this step with the other plastic cover.
  6. XQ-673H Power Cord Replacement: step 6, image 1 of 2 XQ-673H Power Cord Replacement: step 6, image 2 of 2
    • Remove the Power Cord from the device.
Sean Perry
425 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 229
