XQ-673H Power Switch Replacement
  1. XQ-673H Power Switch Replacement, Power Switch: step 1, image 1 of 1
    • Turn the Kitchen Gourmet upside down.
    • Make sure the device is unplugged before continuing.
  2. XQ-673H Power Switch Replacement: step 2, image 1 of 3 XQ-673H Power Switch Replacement: step 2, image 2 of 3 XQ-673H Power Switch Replacement: step 2, image 3 of 3
    • Using a phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
    • Remove the bottom cover.
  3. XQ-673H Power Switch Replacement: step 3, image 1 of 2 XQ-673H Power Switch Replacement: step 3, image 2 of 2
    • Using a Plastic Opening Tool, carefully slide back the three power connectors for the Power Switch until fully removed.
  4. XQ-673H Power Switch Replacement: step 4, image 1 of 3 XQ-673H Power Switch Replacement: step 4, image 2 of 3 XQ-673H Power Switch Replacement: step 4, image 3 of 3
    • Gently squeeze the sides of the Power Switch, while using a Spudger to help pop out the Power Switch.
Sean Perry
425 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 326
