XQ-673H Water Tubes Replacement
  1. XQ-673H Water Tubes Replacement, Water Tubes: step 1, image 1 of 1
    • Make sure the device is unplugged before continuing.
    • Turn the Kitchen Gourmet upside down.
  2. XQ-673H Water Tubes Replacement: step 2, image 1 of 3 XQ-673H Water Tubes Replacement: step 2, image 2 of 3 XQ-673H Water Tubes Replacement: step 2, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
    • Remove the bottom cover.
  3. XQ-673H Water Tubes Replacement: step 3, image 1 of 2 XQ-673H Water Tubes Replacement: step 3, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the six 12mm screws.
    • Some screws are not visible from this photo, but their location is highlighted by the circles.
  4. XQ-673H Water Tubes Replacement: step 4, image 1 of 3 XQ-673H Water Tubes Replacement: step 4, image 2 of 3 XQ-673H Water Tubes Replacement: step 4, image 3 of 3
    • Using small needle nose pliers, squeeze the metal that is covering the tube.
    • Carefully slide down the metal covering.
    • Repeat this step for the other tube.
  5. XQ-673H Water Tubes Replacement: step 5, image 1 of 2 XQ-673H Water Tubes Replacement: step 5, image 2 of 2
    • Using your fingers, gently slide off the Water Tubes.
  6. XQ-673H Water Tubes Replacement: step 6, image 1 of 2 XQ-673H Water Tubes Replacement: step 6, image 2 of 2
    • Carefully lift the bottom section off the device.
  7. XQ-673H Water Tubes Replacement: step 7, image 1 of 2 XQ-673H Water Tubes Replacement: step 7, image 2 of 2
    • Remove both of the Water Tubes completely.
Sean Perry
425 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 732
