Xbox 360 E Wi-Fi Card Replacement
  1. Xbox 360 E Wi-Fi Card Replacement, Top Panel: step 1, image 1 of 1
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Xbox 360 E Wi-Fi Card Replacement: step 2, image 1 of 1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Xbox 360 E Wi-Fi Card Replacement: step 3, image 1 of 3 Xbox 360 E Wi-Fi Card Replacement: step 3, image 2 of 3 Xbox 360 E Wi-Fi Card Replacement: step 3, image 3 of 3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
  4. Xbox 360 E Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 1 of 1
    • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
    In my case it was a T10 Screw, not T9
    Limer o - Reply
  5. Xbox 360 E Wi-Fi Card Replacement: step 5, image 1 of 2 Xbox 360 E Wi-Fi Card Replacement: step 5, image 2 of 2
    • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
    On that wifi card there is a little port that you can plug and old router antena into. Any idea what its called?
    Tyler Goyette - Reply
5 other people completed this guide.
Jennifer
2,020 Reputation
4 Guides authored
Cal Poly, Team 2-11, Amido Winter 2014 Member of Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Members
44 Guides authored
One Comment
Nicely done!
dakota.1970 - Reply
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 66
All Time: 11,126
