Xbox 360 Wireless Controller Analog Stick Covers Replacement
  1. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Battery: step 1, image 1 of 2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Battery: step 1, image 2 of 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Rear Case: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Analog Stick Covers Replacement: step 3, image 1 of 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. Xbox 360 Wireless Controller Analog Stick Covers Replacement: step 4, image 1 of 2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: step 4, image 2 of 2
    Spudger
    $2.99
    Buy
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller Analog Stick Covers Replacement: step 5, image 1 of 2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: step 5, image 2 of 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller Analog Stick Covers Replacement: step 6, image 1 of 2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: step 6, image 2 of 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  7. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Vibration Motors: step 7, image 1 of 2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Vibration Motors: step 7, image 2 of 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller Analog Stick Covers Replacement: step 8, image 1 of 2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: step 8, image 2 of 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  9. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Logic Board: step 9, image 1 of 2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Logic Board: step 9, image 2 of 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  10. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Analog Stick Covers: step 10, image 1 of 2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Analog Stick Covers: step 10, image 2 of 2
    • Grasp the right analog stick and pull the cover off its mount peg.
  11. Xbox 360 Wireless Controller Analog Stick Covers Replacement: step 11, image 1 of 2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: step 11, image 2 of 2
    • Remove the left analog stick cover using the same procedure previously described.
97 other people completed this guide.
Brett Hartt
128,242 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,058 Guides authored
3 Comments
unnecessary steps.
3 steps:
remove all 7 screws.
flip upside down remove top plate
pull stick caps off
reinstall in reverse.
you may have to slide the vibration motors into the slots on the top half when putting back together.
zachharrizusnavy - Reply
Hola buenas tardes feliz domingo. Es tan amable de contactarme co algún proveedor de respuestos para mando de la xbox 360. Como circuitos integrados gatillos chips de vinculación entre otros. Selo agradecería
Jose - Reply
For the wired controller, the steps are the same, and you still have to lift a sticker on the back to get to that 7th screw. But the screws are Philips, not Torx.
Fristle - Reply
Past 24 Hours: 12
Past 7 Days: 62
Past 30 Days: 255
All Time: 102,633
