Introduction
Straight forward replacement of the analog joystick on the controller. To much COD Black Ops can leave it feeling loose and can cause a drift. Toughest part of this repair was the disassembly of the controller since it requires a Torx T8h screwdriver. Make sure you have it before starting this repair.
Tool used on this step:Tweezers$4.99
The left stick is the most common one to go bad.
Depress the battery release button on the top of the controller. Remove the battery holder from the controller.
Use tweezers or similar instrument, to peel the barcode sticker from the battery compartment.
Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
Insert a plastic opening tool between the front and rear cases along the left edge of the controller. Rotate the tool toward the front of the controller to pry the two cases apart.
Grasp the controller by the battery compartment and the headphone jack. Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
Tilt the bottom case slightly toward the trigger buttons to slide it off the top case
Here is a view of the inside of the controller. Note the vibration motors having different counter weights.
Remove the connector from the left motor (controller is positioned upside down, left controller will be shown right etc.)
To remove the left analog stick, the left trigger button will have to be removed first. Desolder the three solder points. Use desoldering wick and some flux to remove the solder.
Left trigger points unsoldered.
There are 2 snaps holding the left trigger piece in place, remove those. It may take a bit of force, but simply push the snap over and down.
48 other people completed this guide.
14 Guide Comments
My controller left stick is physically okew..but in gaming it is moving on downwards...
How can I fix this,I don't knew to do this repairing!:(
Nice work, excellenté!
I would like to note, you can unscrew the security screws with a 00 Flat head screwdriver. I just did it now and got all the screws out. Just gotta find the sweet spot, but it works.
Where do you purchase the actual 2-axis module that get resoldered to the board?
muy buen tutorial, ¿¿¿no te sabras los valores de los condensadores c5 y c71??? es que tube un incidente y los arranque los dos.
un saludo
