Xbox One Elite Controller (Model 1698) Disassembly
  1. Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: step 1, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: step 1, image 2 of 2
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad.
  2. Xbox One Elite Controller (Model 1698) Disassembly, Removing the back panel screws: step 2, image 1 of 1
    • Remove the 5 Torx Security Bit (TR9) screws.
  3. Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: step 3, image 1 of 3 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: step 3, image 2 of 3 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: step 3, image 3 of 3
    • Pry the panel next to the 3.5mm port.
    • Be careful to not rip the ribbon shown in the next step.
  4. Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: step 4, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: step 4, image 2 of 2
    • Be careful to not rip the ribbon cable.
    • You can pop the connector up to remove the ribbon easily.
    • Ribbon Cable
  5. Xbox One Elite Controller (Model 1698) Disassembly, Screws on controller motherboard: step 5, image 1 of 1
    • Remove the 2 Torx (T6) screws.
  6. Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: step 6, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: step 6, image 2 of 2
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
  7. Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: step 7, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: step 7, image 2 of 2
    • Pull up from the "top" side of the controller on the daughterboard.
  8. Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: step 8, image 1 of 3 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: step 8, image 2 of 3 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: step 8, image 3 of 3
    • Be Careful to not lose the sync button.
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part.
  9. Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: step 9, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: step 9, image 2 of 2
    • Unscrew the 6 Torx (T6) screws.
  10. Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: step 10, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: step 10, image 2 of 2
    • Now you can remove the buttons themselves.
43 other people completed this guide.
EasyAsABC123
2,515 Reputation
5 Guides authored
14 Guide Comments
Is there any way I could just do step 8, removing the Home cover? I simply need to fix my USB port so i dont really wanna take it completely apart just for that.
jones_8515 - Reply
Desoldering the rumble motors isn't necessary, nor is removing the first motherboard. Once you get that back panel off, you're golden.
J'Anthony Joseph -
Ya hi i opened my controller and right away i don’t see ether bolt in both handles. 4 i believe to top two bottom.
Suggestions please.
Craig Amyotte - Reply
I found using a TQ5 for the 2 motherboard screws worked the best on my controller not a T6
Mat - Reply
Thanks for the info
EasyAsABC123 -
Past 24 Hours: 11
Past 7 Days: 84
Past 30 Days: 356
All Time: 102,854
