Xbox One S All Digital Edition Fan Replacement
  1. Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: step 1, image 1 of 3 Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: step 1, image 2 of 3 Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: step 1, image 3 of 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Fan Replacement: step 2, image 1 of 2 Xbox One S All Digital Edition Fan Replacement: step 2, image 2 of 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Fan Replacement: step 3, image 1 of 2 Xbox One S All Digital Edition Fan Replacement: step 3, image 2 of 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Fan Replacement: step 4, image 1 of 1
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Fan Replacement, Top Metal Shield: step 5, image 1 of 2 Xbox One S All Digital Edition Fan Replacement, Top Metal Shield: step 5, image 2 of 2
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Fan Replacement: step 6, image 1 of 3 Xbox One S All Digital Edition Fan Replacement: step 6, image 2 of 3 Xbox One S All Digital Edition Fan Replacement: step 6, image 3 of 3
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Fan Replacement, IR Blaster: step 7, image 1 of 2 Xbox One S All Digital Edition Fan Replacement, IR Blaster: step 7, image 2 of 2
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
  8. Xbox One S All Digital Edition Fan Replacement: step 8, image 1 of 2 Xbox One S All Digital Edition Fan Replacement: step 8, image 2 of 2
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
  9. Xbox One S All Digital Edition Fan Replacement, Wifi Card: step 9, image 1 of 2 Xbox One S All Digital Edition Fan Replacement, Wifi Card: step 9, image 2 of 2
    • Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
    • The top of the metal chassis has been removed in the picture, but is not necessary for the replacement.
  10. Xbox One S All Digital Edition Fan Replacement: step 10, image 1 of 1
    • Carefully remove the WiFi Card from the metal chassis.
  11. Xbox One S All Digital Edition Fan Replacement, Bottom Metal Shield: step 11, image 1 of 2 Xbox One S All Digital Edition Fan Replacement, Bottom Metal Shield: step 11, image 2 of 2
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
  12. Xbox One S All Digital Edition Fan Replacement: step 12, image 1 of 3 Xbox One S All Digital Edition Fan Replacement: step 12, image 2 of 3 Xbox One S All Digital Edition Fan Replacement: step 12, image 3 of 3
    • Remove the two plastic pieces from the motherboard.
  13. Xbox One S All Digital Edition Fan Replacement: step 13, image 1 of 3 Xbox One S All Digital Edition Fan Replacement: step 13, image 2 of 3 Xbox One S All Digital Edition Fan Replacement: step 13, image 3 of 3
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
  14. Xbox One S All Digital Edition Fan Replacement, Fan: step 14, image 1 of 2 Xbox One S All Digital Edition Fan Replacement, Fan: step 14, image 2 of 2
    • Locate the 4-pin connector on the side of the fan assembly.
    • Disconnect the cable from the motherboard.
  15. Xbox One S All Digital Edition Fan Replacement: step 15, image 1 of 2 Xbox One S All Digital Edition Fan Replacement: step 15, image 2 of 2
    • Use a spudger to pry the fan tabs up and away from the heatsink.
    • Getting the fan detached can take some force. A metal tool might be required.
  16. Xbox One S All Digital Edition Fan Replacement: step 16, image 1 of 2 Xbox One S All Digital Edition Fan Replacement: step 16, image 2 of 2
    • Lift the fan away to fully remove it.
Jules Hajjar
1,573 Reputation
8 Guides authored
Cal Poly, Team S12-G6, Regan Fall 2019 Member of Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Members
26 Guides authored
0 Comments
Past 24 Hours: 9
Past 7 Days: 33
Past 30 Days: 167
All Time: 7,578
