Xbox One S Motherboard Replacement
  1. Xbox One S Motherboard Replacement, Case: step 1, image 1 of 1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Motherboard Replacement: step 2, image 1 of 1
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
  3. Xbox One S Motherboard Replacement: step 3, image 1 of 1
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Motherboard Replacement: step 4, image 1 of 2 Xbox One S Motherboard Replacement: step 4, image 2 of 2
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
  5. Xbox One S Motherboard Replacement: step 5, image 1 of 2 Xbox One S Motherboard Replacement: step 5, image 2 of 2
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
  6. Xbox One S Motherboard Replacement, Hard Drive Assembly: step 6, image 1 of 2 Xbox One S Motherboard Replacement, Hard Drive Assembly: step 6, image 2 of 2
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C5, from the backside of the Xbox One S.
    • Some models may require C4 and C5.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
  7. Xbox One S Motherboard Replacement: step 7, image 1 of 3 Xbox One S Motherboard Replacement: step 7, image 2 of 3 Xbox One S Motherboard Replacement: step 7, image 3 of 3
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
  8. Xbox One S Motherboard Replacement, Optical Drive Assembly: step 8, image 1 of 1
    • To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C4."
  9. Xbox One S Motherboard Replacement: step 9, image 1 of 1
    • Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
  10. Xbox One S Motherboard Replacement, Motherboard: step 10, image 1 of 1
    • To replace the motherboard you must remove the three silver 10 mm T-10 Torx screws labelled "C1," "C2," and "C6."
    • Remove the four black 8 mm T-8 Torx screws lablelled "A1," "A2," "A3," and "A4."
  11. Xbox One S Motherboard Replacement: step 11, image 1 of 1
    • Locate the rectangular silver clamp on the opposite corner of the power block.
    • Remove the black bracket near the fan.
  12. Xbox One S Motherboard Replacement: step 12, image 1 of 1
    Tool used on this step:
    Buy
    • Grab the clamp with the tweezers. Pull the clamp upward, away from the silver casing. Jiggle it back and forth like a tooth if necessary.
    • It's okay to apply a little bit of force here to get the clamp off the silver casing. The metal is bendable and can be bent/clamped back on.
  13. Xbox One S Motherboard Replacement, Remove Wifi antenna: step 13, image 1 of 1
    • Remove the four black 8 mm T-9 Torx screws labeled "E1," "E2," "E3," and "E4."
  14. Xbox One S Motherboard Replacement, Remove Mediatek board: step 14, image 1 of 1
    • Remove the three black 8 mm T-9 Torx screws labeled "D1," "D2," and "D3" to remove the Mediatek board.
  15. Xbox One S Motherboard Replacement: step 15, image 1 of 1
    • Now that the clamp is removed, gently lift the motherboard from its edges out from the metal casing. The motherboard should come out with ease.
66 other people completed this guide.
Erik Ramazzini
3,204 Reputation
3 Guides authored
Cal Poly, Team S22-G3, Livingston Spring 2017 Member of Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 Members
59 Guides authored
10 Guide Comments
This guide is really missing alot between steps 13 and 14. There are two black panels that have to be removed(they’re in the teardown guide). One is on the front with with screws E1 ,E2, E3, E4. And theres another panel on the side with screws D1, D2, D3. Finally there are two more screws on the bottom that hold down the motherboard B1, and B2. Theres Also a black from in between the Fan and case that slides off too.
Nathan Stanley - Reply Share
Yep, I was using this guide and realized that it is missing a few vital steps. Thank you Nathan.
Dave Miller - Share
If you have a multimeter could you please test the test points around the board and give me a list of a voltages?
Lilithe Lotor - Reply Share
fantastic! only issues that are missing, are mentioned in the comments above. I´d like to include that most of the exterior hardcase clips are made to be HELD in place. Which is why it´s a nuisanse to remove. So, newcomers be careful with it. otherwise you´ll easily break it.
Mateus Cesar Loubach - Reply Share
Son los mejores
NELSON ESTREMERA - Reply Share
Past 24 Hours: 33
Past 7 Days: 171
Past 30 Days: 816
All Time: 74,692
