Xbox One Upper Metal Case Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Xbox One Upper Metal Case Replacement, Upper Metal Case: step 1, image 1 of 3 Xbox One Upper Metal Case Replacement, Upper Metal Case: step 1, image 2 of 3 Xbox One Upper Metal Case Replacement, Upper Metal Case: step 1, image 3 of 3
    • Gently pull up on the speaker cable connector to disconnect it from the front panel board.
    • Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely.
    • Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
  2. Xbox One Upper Metal Case Replacement: step 2, image 1 of 3 Xbox One Upper Metal Case Replacement: step 2, image 2 of 3 Xbox One Upper Metal Case Replacement: step 2, image 3 of 3
    • Remove the two 9.5 mm T8 Torx screws from the WI-Fi board.
    • Lift the Wi-Fi board straight up from its socket in the upper metal case.
    • Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
  3. Xbox One Upper Metal Case Replacement: step 3, image 1 of 1
    • Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
  4. Xbox One Upper Metal Case Replacement: step 4, image 1 of 2 Xbox One Upper Metal Case Replacement: step 4, image 2 of 2
    • Lift—but do not remove—the upper metal case.
    • The Wi-Fi board interconnect cable connects the upper metal case to the motherboard.
  5. Xbox One Upper Metal Case Replacement: step 5, image 1 of 2 Xbox One Upper Metal Case Replacement: step 5, image 2 of 2
    • Disconnect the Wi-Fi board interconnect cable from the motherboard.
    • Remove the upper metal case.
2 other people completed this guide.
Andrew Optimus Goldheart
513,361 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,240 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 39
All Time: 373
