Xbox One Wireless Controller (1697 Model) D-pad Replacement
  1. Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: step 1, image 1 of 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: step 1, image 2 of 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: step 1, image 3 of 3
    • Remove the side handles with the iFixit plastic opening tool by wedging it around the seam of the handles.
    • Be careful not to break the clips when removing the handles.
  2. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 2, image 1 of 1
    • Remove the battery cover and the batteries by sliding the cover up.
  3. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 3, image 1 of 1
    • Remove the two screws (four total screws) on the top and bottom of each controller handle and one screw underneath the battery pack using the T9 Torx screwdriver.
    • The screw underneath the battery pack is located under the sticker.
  4. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 4, image 1 of 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 4, image 2 of 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 4, image 3 of 3
    • Remove the front cover of the controller. using the spudger.
  5. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 5, image 1 of 1
    • Remove the back cover of the controller using the spudger.
  6. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 6, image 1 of 2 Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 6, image 2 of 2
    • Remove the metal ring surrounding the D-pad.
  7. Xbox One Wireless Controller (1697 Model) D-pad Replacement: step 7, image 1 of 1
    • Remove the D-pad from the device.
13 other people completed this guide.
1 Guide Comment
Hellow mine has a problem that it doesn't work\turn on with battery or with a cable like its dead
Abdulhamid - Reply
Past 24 Hours: 9
Past 7 Days: 55
Past 30 Days: 179
All Time: 11,750
