Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement
  1. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement, Hard Drive/ Solid State Drive: step 1, image 1 of 1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: step 2, image 1 of 2 Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: step 2, image 2 of 2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: step 3, image 1 of 1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with a nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: step 4, image 1 of 1
    • Remove the solid state drive.
7 other people completed this guide.
3 Guide Comments
WHAT DO i REPLACE THE ssd WITH ONCE REMOVED? I WANT TO UPGRADE TO A 1TB DRIVE. WHAT DO YOU SUGGEST FOR MY LENOVO 110S-141BR LAPTOP?
ROBERT GOFFINSKI - Reply
I replaced with an ssd but the laptop is not recognizing it
Janet Zinabe - Reply
merci beaucoup
kateba charles - Reply
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 73
All Time: 16,934
