Xbox Series S Power Button Board Replacement
  1. Xbox Series S Power Button Board Replacement, Peel off the sticker coverings: step 1, image 1 of 3 Xbox Series S Power Button Board Replacement, Peel off the sticker coverings: step 1, image 2 of 3 Xbox Series S Power Button Board Replacement, Peel off the sticker coverings: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
  2. Xbox Series S Power Button Board Replacement, Remove the back panel screws: step 2, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  3. Xbox Series S Power Button Board Replacement, Remove the bottom panel: step 3, image 1 of 3 Xbox Series S Power Button Board Replacement, Remove the bottom panel: step 3, image 2 of 3 Xbox Series S Power Button Board Replacement, Remove the bottom panel: step 3, image 3 of 3
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  4. Xbox Series S Power Button Board Replacement, Remove the plastic case screws: step 4, image 1 of 1
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  5. Xbox Series S Power Button Board Replacement, Remove the plastic case: step 5, image 1 of 3 Xbox Series S Power Button Board Replacement, Remove the plastic case: step 5, image 2 of 3 Xbox Series S Power Button Board Replacement, Remove the plastic case: step 5, image 3 of 3
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  6. Xbox Series S Power Button Board Replacement: step 6, image 1 of 3 Xbox Series S Power Button Board Replacement: step 6, image 2 of 3 Xbox Series S Power Button Board Replacement: step 6, image 3 of 3
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
  7. Xbox Series S Power Button Board Replacement, Remove the power button board: step 7, image 1 of 1
    • Use a T8 Torx driver to remove the 9.5 mm-long screw securing the power button board to the chassis.
  8. Xbox Series S Power Button Board Replacement: step 8, image 1 of 3 Xbox Series S Power Button Board Replacement: step 8, image 2 of 3 Xbox Series S Power Button Board Replacement: step 8, image 3 of 3
    • Use a spudger to pry and loosen the power button board.
    • Do not pry from the bottom of the power button board as it may bend the connector.
    • Pull the power button board straight out to disconnect it from the chassis.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Robert Boyd
29,304 Reputation
94 Guides authored
One Comment
Can you tell me what on the power button board turns the console on?
Dreshaun Norman - Reply
Past 24 Hours: 6
Past 7 Days: 45
Past 30 Days: 138
All Time: 4,528
