Xbox Series X|S Controller (Model 1914) Back Housing Replacement
  1. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the battery cover: step 1, image 1 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the battery cover: step 1, image 2 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the battery cover: step 1, image 3 of 3
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the batteries: step 2, image 1 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the batteries: step 2, image 2 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the batteries: step 2, image 3 of 3
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
  3. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: step 3, image 1 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: step 3, image 2 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: step 3, image 3 of 3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  4. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the left handle cover clips: step 4, image 1 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the left handle cover clips: step 4, image 2 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the left handle cover clips: step 4, image 3 of 3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  5. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the left handle cover: step 5, image 1 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the left handle cover: step 5, image 2 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the left handle cover: step 5, image 3 of 3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  6. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: step 6, image 1 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: step 6, image 2 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: step 6, image 3 of 3
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  7. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the right handle cover clips: step 7, image 1 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the right handle cover clips: step 7, image 2 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the right handle cover clips: step 7, image 3 of 3
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  8. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the right handle cover: step 8, image 1 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the right handle cover: step 8, image 2 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the right handle cover: step 8, image 3 of 3
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  9. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Reposition the battery compartment sticker: step 9, image 1 of 2 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Reposition the battery compartment sticker: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
  10. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Unfasten the top housing: step 10, image 1 of 2 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Unfasten the top housing: step 10, image 2 of 2
    • Use a Torx T8 Security screwdriver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
  11. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the top housing: step 11, image 1 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the top housing: step 11, image 2 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the top housing: step 11, image 3 of 3
    • Lift the top housing straight up to remove it.
  12. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Pry up the midframe assembly: step 12, image 1 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Pry up the midframe assembly: step 12, image 2 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Pry up the midframe assembly: step 12, image 3 of 3
    • Insert the flat end of a spudger into the rectangular gap between the midframe assembly and back housing, nearest the left bumper.
    • Twist the spudger to partially release the midframe assembly.
    • Repeat this prying procedure on the gap near the right bumper to completely release the midframe assembly.
  13. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the midframe assembly: step 13, image 1 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the midframe assembly: step 13, image 2 of 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the midframe assembly: step 13, image 3 of 3
4 other people completed this guide.
Manuel Haeussermann
16,160 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,892 Guides authored
0 Comments
Past 24 Hours: 25
Past 7 Days: 124
Past 30 Days: 648
All Time: 5,945
