Introduction
Use this guide to replace the top housing on your Xbox Series X|S Controller (model 1914).
The top housing may need to be replaced if it's cracked, or you may be installing a new, customized one. The top housing is sometimes called a front panel, faceplate or top shell.
Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
Remove the left handle cover.
Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
Remove the right handle cover.
Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
Use a Torx T8 Security screwdriver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
2 other people completed this guide.
