Xbox Series X USB and Pair Button Board Replacement
Spencer Day
Spencer Day
Last updated on December 16, 2024
30 minutes - 1 hour
Moderate
Introduction
Go to step 1
Use this guide to replace the USB and Pair button board in your Xbox Series X.
If your Pair button is sticking or isn't clicking, or if the USB port on the front of your Xbox has a loose connection, you may need to replace the USB and Pair button board.
If your controller isn't syncing to your Xbox, make sure the problem isn't with your controller before replacing the board.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your console.
iFixit earns commission when you buy through these links.
  1. Xbox Series X USB and Pair Button Board Replacement, Uncover the back panel screws: step 1, image 1 of 2 Xbox Series X USB and Pair Button Board Replacement, Uncover the back panel screws: step 1, image 2 of 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X USB and Pair Button Board Replacement: step 2, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement: step 2, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement: step 2, image 3 of 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X USB and Pair Button Board Replacement, Remove the back panel screws: step 3, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X USB and Pair Button Board Replacement, Unclip the back panel: step 4, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Unclip the back panel: step 4, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Unclip the back panel: step 4, image 3 of 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X USB and Pair Button Board Replacement: step 5, image 1 of 2 Xbox Series X USB and Pair Button Board Replacement: step 5, image 2 of 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X USB and Pair Button Board Replacement, Remove the back panel: step 6, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the back panel: step 6, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the back panel: step 6, image 3 of 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X USB and Pair Button Board Replacement: step 7, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement: step 7, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement: step 7, image 3 of 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X USB and Pair Button Board Replacement, Remove the fan screws: step 8, image 1 of 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X USB and Pair Button Board Replacement, Disconnect the fan cable: step 9, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Disconnect the fan cable: step 9, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Disconnect the fan cable: step 9, image 3 of 3
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X USB and Pair Button Board Replacement, Remove the fan: step 10, image 1 of 2 Xbox Series X USB and Pair Button Board Replacement, Remove the fan: step 10, image 2 of 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X USB and Pair Button Board Replacement, Unlatch the base: step 11, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Unlatch the base: step 11, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Unlatch the base: step 11, image 3 of 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X USB and Pair Button Board Replacement, Twist and remove the base: step 12, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Twist and remove the base: step 12, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Twist and remove the base: step 12, image 3 of 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X USB and Pair Button Board Replacement, Remove the optical drive screws: step 13, image 1 of 2 Xbox Series X USB and Pair Button Board Replacement, Remove the optical drive screws: step 13, image 2 of 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X USB and Pair Button Board Replacement, Remove the vibration isolator: step 14, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the vibration isolator: step 14, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the vibration isolator: step 14, image 3 of 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X USB and Pair Button Board Replacement, Disconnect the power and data cables: step 15, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Disconnect the power and data cables: step 15, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Disconnect the power and data cables: step 15, image 3 of 3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X USB and Pair Button Board Replacement, Remove the optical drive: step 16, image 1 of 2 Xbox Series X USB and Pair Button Board Replacement, Remove the optical drive: step 16, image 2 of 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X USB and Pair Button Board Replacement, Disconnect the USB port cable: step 17, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Disconnect the USB port cable: step 17, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Disconnect the USB port cable: step 17, image 3 of 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X USB and Pair Button Board Replacement: step 18, image 1 of 2 Xbox Series X USB and Pair Button Board Replacement: step 18, image 2 of 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
  19. Xbox Series X USB and Pair Button Board Replacement, Disconnect the power button cable: step 19, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Disconnect the power button cable: step 19, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Disconnect the power button cable: step 19, image 3 of 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X USB and Pair Button Board Replacement, Remove the chassis screws: step 20, image 1 of 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X USB and Pair Button Board Replacement, Peel up the USB port cable: step 21, image 1 of 2 Xbox Series X USB and Pair Button Board Replacement, Peel up the USB port cable: step 21, image 2 of 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X USB and Pair Button Board Replacement, Remove the center chassis assembly: step 22, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the center chassis assembly: step 22, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the center chassis assembly: step 22, image 3 of 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X USB and Pair Button Board Replacement, Separate the USB board cable: step 23, image 1 of 2 Xbox Series X USB and Pair Button Board Replacement, Separate the USB board cable: step 23, image 2 of 2
    • The USB board cable is adhered to the shell with pieces of mild adhesive.
    • Use an iOpener or a hair dryer to heat the USB board cable.
  24. Xbox Series X USB and Pair Button Board Replacement: step 24, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement: step 24, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement: step 24, image 3 of 3
    iFixit Opening Picks (Set of 6)
    • Be very careful when lifting the cable where it connects to the board. Peel gently, and slide an opening pick under the cable if you're having trouble separating the adhesive.
    • Use your fingers to peel up the USB board cable and fully separate it from the shell.
    • During reassembly, use thin double‑sided adhesive to secure the cable. If there's adhesive left and it's still sticky, you can reuse it. If you have a new cable, check it for pre‑installed adhesive and remove any liners.
  25. Xbox Series X USB and Pair Button Board Replacement, Remove the USB enclosure screws: step 25, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the USB enclosure screws: step 25, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the USB enclosure screws: step 25, image 3 of 3
    • Use a T8 Torx driver to remove the two 8.9 mm‑long screws securing the USB board enclosure:
    • One screw inside the shell
    • One screw on the bottom of the shell (where the base was)
  26. Xbox Series X USB and Pair Button Board Replacement, Remove the USB enclosure: step 26, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the USB enclosure: step 26, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the USB enclosure: step 26, image 3 of 3
    • Use your fingers to slide the USB board enclosure out from under the metal clip securing it to the shell.
    • Remove the enclosure.
    • During reassembly:
    • Make sure the Pair button is properly oriented and fully inserted in its slot.
    • Firmly slide the enclosure into position until it snaps into place under the metal clip.
  27. Xbox Series X USB and Pair Button Board Replacement, Remove the USB board screws: step 27, image 1 of 2 Xbox Series X USB and Pair Button Board Replacement, Remove the USB board screws: step 27, image 2 of 2
    • Use a T8 Torx driver to remove the four 8.9 mm‑long screws securing the USB board to its enclosure.
  28. Xbox Series X USB and Pair Button Board Replacement, Remove the USB board: step 28, image 1 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the USB board: step 28, image 2 of 3 Xbox Series X USB and Pair Button Board Replacement, Remove the USB board: step 28, image 3 of 3
    • Use your fingers to lift the skinnier side of the board.
    • Pull the board away from the enclosure and out from under its clips to remove it.
    • Check if your replacement board comes with a cable. If it doesn't, remove the cable from your original board and transfer it to your replacement.
    • During reassembly, first insert the board under its clips on the wider edge of the enclosure and then lay the board into place.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
2 other people completed this guide.
Spencer Day
95,619 Reputation
662 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,526 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 159
All Time: 493
