Xelio P900A-BK Screen Replacement
  1. Xelio P900A-BK Screen Replacement, Screen: step 1, image 1 of 1
    • Remove the two bottom screws.
    • The two bottom screws have a 2.44mm wide tops and are 5.44mm.
  2. Xelio P900A-BK Screen Replacement: step 2, image 1 of 2 Xelio P900A-BK Screen Replacement: step 2, image 2 of 2
    • Slide the spludger between the screen's rolled edge and the back of the tablet and pry apart carefully. Expect the tablet screen to make a cracking sound.
    • Slide the spudger in the slit all the way around the perimeter of the tablet to fully separate the screen.
  3. Xelio P900A-BK Screen Replacement: step 3, image 1 of 1
    • Once the screen has fully separated from the back of the tablet, gently lift up the edges to remove the screen.
  4. Xelio P900A-BK Screen Replacement: step 4, image 1 of 2 Xelio P900A-BK Screen Replacement: step 4, image 2 of 2
    • Next, disconnect the front facing camera ribbon (shown). The ribbon is held to the motherboard by a small bar.
    • Using the spudger to pry open the bar, pull the ribbon out to disconnect it.
  5. Xelio P900A-BK Screen Replacement: step 5, image 1 of 2 Xelio P900A-BK Screen Replacement: step 5, image 2 of 2
    • Next, work on disconnecting the ribbon for the touch screen.
    • The touch screen ribbon is larger than the camera ribbon and is located on the left side of motherboard.
    • Using the spudger, gently pry the ribbon out from under the bar. Pull the ribbon and disconnect it from the motherboard.
  6. Xelio P900A-BK Screen Replacement: step 6, image 1 of 3 Xelio P900A-BK Screen Replacement: step 6, image 2 of 3 Xelio P900A-BK Screen Replacement: step 6, image 3 of 3
    • Next, work to disconnect the LCD screen ribbon.
    • This ribbon is located on the right side of the motherboard.
    • The ribbon is connected to the motherboard by a small bar. Using the spudger, pry the bar apart and slide the ribbon out.
  7. Xelio P900A-BK Screen Replacement: step 7, image 1 of 3 Xelio P900A-BK Screen Replacement: step 7, image 2 of 3 Xelio P900A-BK Screen Replacement: step 7, image 3 of 3
    • Remove the two motherboard screws.
    • To remove the first screw, expose the black strip. Then using a Philips head screwdriver, remove the first screw.
    • Locate the second screw by looking to the bottom right of the motherboard. Remove the second screw with the Philips head screwdriver.
  8. Xelio P900A-BK Screen Replacement: step 8, image 1 of 2 Xelio P900A-BK Screen Replacement: step 8, image 2 of 2
    • Locate the last connection to the LCD in the top right section of the tablet.
    • The last connection is a ribbon connected to green wire, which is held down by tape.
    • Disconnect the ribbon by removing the tape connecting it to the plastic frame of the tablet.
  9. Xelio P900A-BK Screen Replacement: step 9, image 1 of 1
    • With the spudger, pry the LCD screen from the plastic screen holder.
    • Use gentle, but firm force to pry the LCD away from the holder.
  10. Xelio P900A-BK Screen Replacement: step 10, image 1 of 1
    • Work the spudger all the way around until the LCD is free from the screen holder.
  11. Xelio P900A-BK Screen Replacement: step 11, image 1 of 1
    • Finally, lift the LCD off, removing it from the screen holder and the motherboard.
Marcus Nelson
307 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 6
All Time: 406
