Xiaomi Mi 8 Battery Replacement
  1. Xiaomi Mi 8 Battery Replacement, Rear Glass: step 1, image 1 of 1
    • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
  2. Xiaomi Mi 8 Battery Replacement: step 2, image 1 of 3 Xiaomi Mi 8 Battery Replacement: step 2, image 2 of 3 Xiaomi Mi 8 Battery Replacement: step 2, image 3 of 3
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If the glass wont budge, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner of the phone.
  3. Xiaomi Mi 8 Battery Replacement: step 3, image 1 of 2 Xiaomi Mi 8 Battery Replacement: step 3, image 2 of 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Mi 8 Battery Replacement: step 4, image 1 of 3 Xiaomi Mi 8 Battery Replacement: step 4, image 2 of 3 Xiaomi Mi 8 Battery Replacement: step 4, image 3 of 3
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 8 to cut the adhesive.
    • Be aware of the fingerprint flex cable and only insert the tip of the opening pick. If insert to deep, you can cut the cable by accident.
    • As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    The back cover of MI 8 easily breaks while sliding the opening pick because it is made of fragile glass. Before sliding the pick, rim of the back cover should be heated enough to make adhesive loose.
    Shunsuke Abe - Reply
  5. Xiaomi Mi 8 Battery Replacement: step 5, image 1 of 2 Xiaomi Mi 8 Battery Replacement: step 5, image 2 of 2
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Mi 8 Battery Replacement: step 6, image 1 of 2 Xiaomi Mi 8 Battery Replacement: step 6, image 2 of 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right edge to cut the remaining adhesive.
    • Don't try to remove the rear glass all the way yet. The fingerprint flex cable is still connected to the motherboard.
  7. Xiaomi Mi 8 Battery Replacement: step 7, image 1 of 2 Xiaomi Mi 8 Battery Replacement: step 7, image 2 of 2
    • Carefully lift the rear glass and fold it to the left side to access the fingerprint flex connector.
  8. Xiaomi Mi 8 Battery Replacement: step 8, image 1 of 2 Xiaomi Mi 8 Battery Replacement: step 8, image 2 of 2
    • Use a spudger to pry up and disconnect the fingerprint flex cable.
    • Remove the rear glass.
    • Before installing new adhesive for reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond. A stack of heavy books on top of the phone works well.
  9. Xiaomi Mi 8 Battery Replacement, Motherboard Cover with NFC: step 9, image 1 of 1
    • Remove the ten screws that secure the motherboard cover.
    • Eight Phillips #00 screws (3.4 mm length)
    • Two Phillips #00 screws (3.5 mm length)
    Bei dem MI 8 ist (auf dem Bild gesehen) unten links noch eine Schraube (3,4 mm #00 Kreuzschlitzschraube) die zum Entfernen des Motherboards gelöst werden muß
    Jürgen Dreßler - Reply
    Hallo Jürgen, danke für den Hinweis. Die Schraube wurde übersehen und ich habe den Schritt entsprechend angepasst.
    Dominik Schnabelrauch - Reply
  10. Xiaomi Mi 8 Battery Replacement: step 10, image 1 of 2 Xiaomi Mi 8 Battery Replacement: step 10, image 2 of 2
    • Slide an opening pick under the right side of the motherboard cover.
    • Twist the opening pick sideways to pry up and slightly lift the motherboard cover.
  11. Xiaomi Mi 8 Battery Replacement: step 11, image 1 of 2 Xiaomi Mi 8 Battery Replacement: step 11, image 2 of 2
    • Carefully remove the motherboard cover including the NFC antenna.
  12. Xiaomi Mi 8 Battery Replacement, Battery Disconnect: step 12, image 1 of 2 Xiaomi Mi 8 Battery Replacement, Battery Disconnect: step 12, image 2 of 2
    • Use a spudger to pry up and disconnect the battery flex cable located at the bottom of the motherboard.
  13. Xiaomi Mi 8 Battery Replacement, Battery: step 13, image 1 of 3 Xiaomi Mi 8 Battery Replacement, Battery: step 13, image 2 of 3 Xiaomi Mi 8 Battery Replacement, Battery: step 13, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers to peel the black ends of the adhesive tabs off the battery.
  14. Xiaomi Mi 8 Battery Replacement: step 14, image 1 of 1
    • For the following steps:
    • The adhesive tab underneath the battery can rip very easily. Make sure you pull out the tab in a slow and steady motion and at a flat angle. To prevent the adhesive tab from ripping, it's helpful to twist it around the tweezers.
  15. Xiaomi Mi 8 Battery Replacement: step 15, image 1 of 2 Xiaomi Mi 8 Battery Replacement: step 15, image 2 of 2
    • Pull out the first adhesive tab from underneath the battery.
  16. Xiaomi Mi 8 Battery Replacement: step 16, image 1 of 2 Xiaomi Mi 8 Battery Replacement: step 16, image 2 of 2
    Plastic Cards
    $2.99
    Buy
    • Use a pair of tweezers to pull out the second adhesive tab from underneath the battery.
    • In case one of the adhesive tabs rips and it‘s not possible to pull it out completely, you can use isopropyl alcohol or a heated iOpener to loosen the adhesive. After the adhesive is soft enough use a prying tool such as an opening pick or a plastic card to pry out the battery.
  17. Xiaomi Mi 8 Battery Replacement: step 17, image 1 of 2 Xiaomi Mi 8 Battery Replacement: step 17, image 2 of 2
    • Use an opening pick or plastic card to pry the battery out of its recess until you can get a good grip.
  18. Xiaomi Mi 8 Battery Replacement: step 18, image 1 of 2 Xiaomi Mi 8 Battery Replacement: step 18, image 2 of 2
    • Remove the battery.
    • Reusing a deformed or bent battery after it has forcefully been removed, is a potential safety hazard. Replace it with a new battery.
    • Remove any remaining adhesive from the midframe, and clean the glued areas with isopropyl alcohol and a lint-free cloth before applying new adhesive.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
26 other people completed this guide.
228,969 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
12 Comments
Thanks ! Its helps me alot
Andre Maseliku - Reply
excellent, thanks
Ronald - Reply
Echt Klasse, allerdings sind es 8 schwarze schrauben bei der Mainboard Abdeckung. Ansonsten echt top Anleitung, vielen Dank
Kristijan Likarevic - Reply
Die deutsche Übersetzung war veraltet, ich habe sie aktualisiert. Danke! Viel Spaß mit deinem Xiaomi.
Fabian Neidhardt -
Danke für die Anleitung erstmal. Ich habe jedoch die Keramik Version des Mi8 und bei mir scheitert es bereits beim Anheben der Rückabdeckung. Diese gibt quasi überhaupt nicht nach und ich bekommen kein Spektrum dazwischen. Irgendwelche Tipps?
Gregor - Reply
Hej Gregor, vielleicht ist das Keramik nicht ganz so leitfähig wie das Glas. Dann müsstest du die Rückseite ein wenig länger erwärmen, um den Kleber aufzuweichen.
Fabian Neidhardt -
Das Problem hatte ich auch anfangs. Mit dem Messer bin ich dann letztendlich doch rein gekommen und habe einen ausreichend großen Spalt geschaffen um mit den Plektren wie gezeigt fortzufahren.
Kilian Schmitz -
Thanks for the tutorial! Which adhesive tape would be the most suitable? 2mm?
Mario - Reply
This review doesn't mention anything about where to get the adhesive from (should be in parts!), I bought the battery and it doesn't include the adhesive.
Aside from that you will need to change the glue on the rear part of your phone, again it's not mentioned!
Iu Ayala - Reply
Wo soll man den neuen Kleber herbekommen?
Boskalis - Reply
Ersatzklebestreifen bekommst du bei iFixit im Store.
Fabian Neidhardt -
Thankyou so much! Worked flawlessly :)
MastaGlazy - Reply
Past 24 Hours: 11
Past 7 Days: 61
Past 30 Days: 258
All Time: 30,920
