Xiaomi Mi 8 Fingerprint Sensor Replacement
  1. Xiaomi Mi 8 Fingerprint Sensor Replacement, Rear Glass: step 1, image 1 of 1
    • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
  2. Xiaomi Mi 8 Fingerprint Sensor Replacement: step 2, image 1 of 3 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 2, image 2 of 3 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 2, image 3 of 3
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If the glass wont budge, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner of the phone.
  3. Xiaomi Mi 8 Fingerprint Sensor Replacement: step 3, image 1 of 2 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 3, image 2 of 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Mi 8 Fingerprint Sensor Replacement: step 4, image 1 of 3 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 4, image 2 of 3 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 4, image 3 of 3
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 8 to cut the adhesive.
    • Be aware of the fingerprint flex cable and only insert the tip of the opening pick. If insert to deep, you can cut the cable by accident.
    • As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Mi 8 Fingerprint Sensor Replacement: step 5, image 1 of 2 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 5, image 2 of 2
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Mi 8 Fingerprint Sensor Replacement: step 6, image 1 of 2 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 6, image 2 of 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right edge to cut the remaining adhesive.
    • Don't try to remove the rear glass all the way yet. The fingerprint flex cable is still connected to the motherboard.
  7. Xiaomi Mi 8 Fingerprint Sensor Replacement: step 7, image 1 of 2 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 7, image 2 of 2
    • Carefully lift the rear glass and fold it to the left side to access the fingerprint flex connector.
  8. Xiaomi Mi 8 Fingerprint Sensor Replacement: step 8, image 1 of 2 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 8, image 2 of 2
    • Use a spudger to pry up and disconnect the fingerprint flex cable.
    • Remove the rear glass.
    • Before installing new adhesive for reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond. A stack of heavy books on top of the phone works well.
  9. Xiaomi Mi 8 Fingerprint Sensor Replacement, Fingerprint Sensor: step 9, image 1 of 1
    • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the fingerprint sensor. Apply the iOpener for at least two minutes.
  10. Xiaomi Mi 8 Fingerprint Sensor Replacement: step 10, image 1 of 2 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 10, image 2 of 2
    • The fingerprint flex cable is mildly glued to the rear glass. Carefully slide an opening pick underneath to separate it from the glass.
  11. Xiaomi Mi 8 Fingerprint Sensor Replacement: step 11, image 1 of 3 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 11, image 2 of 3 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 11, image 3 of 3
    • Insert an opening pick under the top right corner of the fingerprint sensor.
    • Slide the opening pick along the top edge of the sensor to cut the adhesive.
  12. Xiaomi Mi 8 Fingerprint Sensor Replacement: step 12, image 1 of 2 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 12, image 2 of 2
    • Slide the opening pick under the center of the sensor and twist it sideways to pry it up until you can get a good grip.
  13. Xiaomi Mi 8 Fingerprint Sensor Replacement: step 13, image 1 of 2 Xiaomi Mi 8 Fingerprint Sensor Replacement: step 13, image 2 of 2
    • Remove the fingerprint sensor.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
2 other people completed this guide.
Dominik Schnabelrauch
248,408 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,829 Guides authored
1 Guide Comment
This is so informative, one of my friend had this issue so I bought the replacement part followed this steps and its quiet easier to replace the flex cable.
harshithaemazel - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 43
All Time: 3,106
