Introduction
I only repair devices very occasionally, so I can not help with grounding, grounding gloves and heat guns.
I used a cheap repair kit that doesn't allow fingerprinting and supplemented it with existing tools I had at home.
Here is the link to the replacement parts:
Heat the back cover and use plastic tools to carefully pry it off.
Attention: There is also adhesive around the camera
Carefully disconnect the connection to the battery
Remove the screws holding down the lower inner cover and carefully remove it.
First, carefully disconnect the lower connector.
Attention: The silver foil is adhesive foil and will be needed again later, so heat it up beforehand and loosen it carefully.
The adapter comes out from under the adhesive foil.
Then, carefully loosen the upper connector and put the cable aside.
Heat the edges of the display and carefully remove it.
Attention: Carefully remove the screen cable.
Remove the plastic cover on the rear side of the new display.
Apply the adhesive to the edge of the display.
Connect the display cable to new display.
Press the display down.
Reconnect the display cable with the connecting cable.
Use adhesive film to reattach.
Reattach the upper part of the connecting cable.
Reinstall and tighten the lower inner cover.
Apply glue to the edge of the back plate.
Reattach the back plate.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
