Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement
  1. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement, Screen (LCD+Touch): step 1, image 1 of 2 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement, Screen (LCD+Touch): step 1, image 2 of 2
    • Turn off and remove the SIM card.
  2. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 2, image 1 of 3 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 2, image 2 of 3 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 2, image 3 of 3
    • Apply heat to loosen the back cover adhesive. Then remove it carefully.
  3. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 3, image 1 of 2 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 3, image 2 of 2
    • Remove all nine screws that hold the shield protecting the motherboard.
  4. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 4, image 1 of 3 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 4, image 2 of 3 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 4, image 3 of 3
    • Remove the shield and disconnect the battery connector, LCD and touch connector, and touch ID connector.
  5. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 5, image 1 of 3 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 5, image 2 of 3 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 5, image 3 of 3
    • Remove the battery carefully as shown and apply heat to loosen the adhesive holding the screen.
  6. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 6, image 1 of 3 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 6, image 2 of 3 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 6, image 3 of 3
    • Carefully start to separate the screen as shown. Start from the top corner.
  7. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 7, image 1 of 2 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: step 7, image 2 of 2
    • You have done it.
8 other people completed this guide.
Kefelegn Derbew
553 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 111
All Time: 7,638
