Xiaomi Mi Note Front camera Replacement
  1. Xiaomi Mi Note Front camera Replacement, Dual SIM SD Card: step 1, image 1 of 1
    • Locate the hole for the Dual SIM SD card on the left side of the phone.
  2. Xiaomi Mi Note Front camera Replacement: step 2, image 1 of 2 Xiaomi Mi Note Front camera Replacement: step 2, image 2 of 2
    • Use the Dual SIM SD card removal tool (or use a paper clip) and insert it into the slot hole until the tray pops out.
  3. Xiaomi Mi Note Front camera Replacement, Battery: step 3, image 1 of 2 Xiaomi Mi Note Front camera Replacement, Battery: step 3, image 2 of 2
    • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
  4. Xiaomi Mi Note Front camera Replacement: step 4, image 1 of 3 Xiaomi Mi Note Front camera Replacement: step 4, image 2 of 3 Xiaomi Mi Note Front camera Replacement: step 4, image 3 of 3
    • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
    • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
    • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
  5. Xiaomi Mi Note Front camera Replacement: step 5, image 1 of 1
    • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
  6. Xiaomi Mi Note Front camera Replacement: step 6, image 1 of 2 Xiaomi Mi Note Front camera Replacement: step 6, image 2 of 2
    • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
    • Glue will be holding down the backside of the battery.
  7. Xiaomi Mi Note Front camera Replacement, Front camera: step 7, image 1 of 1
    • Use a spudger to pry upwards and detach the three ribbons that are connected to the motherboard.
  8. Xiaomi Mi Note Front camera Replacement: step 8, image 1 of 2 Xiaomi Mi Note Front camera Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to detach the small ribbon on left side located near the volume buttons using an upwards prying motion.
    • You will also need to detach the microphone cord located on the right side along the frame using an upwards prying motion as well.
    • When detaching the ribbon on the left use minimal force to prevent damage.
  9. Xiaomi Mi Note Front camera Replacement: step 9, image 1 of 2 Xiaomi Mi Note Front camera Replacement: step 9, image 2 of 2
    • Use a tweezer to lift and remove the motherboard from the frame.
    • Be sure that the Dual SIM card and tray has been removed.
  10. Xiaomi Mi Note Front camera Replacement: step 10, image 1 of 1
    • The front camera is attached to the motherboard by a ribbon, use tweezers to detach it from the motherboard.
4 other people completed this guide.
Abdulaziz Aldekheel
374 Reputation
2 Guides authored
USF Tampa, Team 1-6, Sullivan Fall 2015 Member of USF Tampa, Team 1-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G6
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 2,834
