Xiaomi Mi Note Screen Replacement
  1. Xiaomi Mi Note Screen Replacement, Dual SIM SD Card: step 1, image 1 of 1
    • Locate the hole for the Dual SIM SD card on the left side of the phone.
  2. Xiaomi Mi Note Screen Replacement: step 2, image 1 of 2 Xiaomi Mi Note Screen Replacement: step 2, image 2 of 2
    • Use the Dual SIM SD card removal tool (or use a paper clip) and insert it into the slot hole until the tray pops out.
  3. Xiaomi Mi Note Screen Replacement, Battery: step 3, image 1 of 2 Xiaomi Mi Note Screen Replacement, Battery: step 3, image 2 of 2
    • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
  4. Xiaomi Mi Note Screen Replacement: step 4, image 1 of 3 Xiaomi Mi Note Screen Replacement: step 4, image 2 of 3 Xiaomi Mi Note Screen Replacement: step 4, image 3 of 3
    • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
    • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
    • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
  5. Xiaomi Mi Note Screen Replacement: step 5, image 1 of 1
    • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
  6. Xiaomi Mi Note Screen Replacement: step 6, image 1 of 2 Xiaomi Mi Note Screen Replacement: step 6, image 2 of 2
    • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
    • Glue will be holding down the backside of the battery.
  7. Xiaomi Mi Note Screen Replacement, Screen: step 7, image 1 of 3 Xiaomi Mi Note Screen Replacement, Screen: step 7, image 2 of 3 Xiaomi Mi Note Screen Replacement, Screen: step 7, image 3 of 3
    • Use a spudger to detach the ribbons connected to the motherboard using an upward prying motion.
  8. Xiaomi Mi Note Screen Replacement: step 8, image 1 of 3 Xiaomi Mi Note Screen Replacement: step 8, image 2 of 3 Xiaomi Mi Note Screen Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to detach the small ribbon on left side located near the volume buttons using an upwards prying motion.
    • You will also need to detach the microphone cord located on the right side along the frame using an upwards prying motion as well.
    • When detaching the ribbon on the left use minimal force to prevent damage.
  9. Xiaomi Mi Note Screen Replacement: step 9, image 1 of 2 Xiaomi Mi Note Screen Replacement: step 9, image 2 of 2
    • Use a tweezer to lift and remove the motherboard from the frame.
    • Be sure that the Dual SIM card and tray has been removed.
  10. Xiaomi Mi Note Screen Replacement: step 10, image 1 of 1
    • Peel back the ribbon that is adhered to the metal surface as shown.
  11. Xiaomi Mi Note Screen Replacement: step 11, image 1 of 3 Xiaomi Mi Note Screen Replacement: step 11, image 2 of 3 Xiaomi Mi Note Screen Replacement: step 11, image 3 of 3
    • The dock connector is firmly adhered to the frame below it. To prevent damage to the phone use minimal force when removing.
    • Using tweezers slowly start prying upwards at the locations shown in the images. After carefully prying around the edges of the dock connector, it can now lifted upwards out of the frame.
  12. Xiaomi Mi Note Screen Replacement: step 12, image 1 of 2 Xiaomi Mi Note Screen Replacement: step 12, image 2 of 2
    • Using a spudger detach the top two ribbons that connect the screen to the touch sensor and motherboard using an upwards prying motion.
  13. Xiaomi Mi Note Screen Replacement: step 13, image 1 of 2 Xiaomi Mi Note Screen Replacement: step 13, image 2 of 2
    • Using tweezers lift the two remaining ribbons from the bottom frame by grasping the ribbons at any point and lifting towards the bottom of the frame.
    • The ribbons should now be able to freely slide through the respective slits once the screen is lose enough to pull away from the frame for later.
  14. Xiaomi Mi Note Screen Replacement: step 14, image 1 of 2 Xiaomi Mi Note Screen Replacement: step 14, image 2 of 2
    • Peel back the ribbon attached to the back metal frame.
    • Use your spudger at any point to get underneath the metal frame. Slide the spudger around the sides of the metal to free it from the frame.
    • Small amounts of adhesive are holding the metal frame in place.
  15. Xiaomi Mi Note Screen Replacement: step 15, image 1 of 3 Xiaomi Mi Note Screen Replacement: step 15, image 2 of 3 Xiaomi Mi Note Screen Replacement: step 15, image 3 of 3
    • Apply considerable force to the back corners using your spudger to help relieve it of the adhesive as shown.
    • Once you have freed the screen from a portion of the adhesive, wedge your spudger around the front edge to work around the edges of the screen and frame in order to fully remove it from the frame.
    • Be aware that the glass screen will break during this process. Be careful not to cut yourself while preforming this step.
21 other people completed this guide.
Mark Sears
1,249 Reputation
4 Guides authored
USF Tampa, Team 1-6, Sullivan Fall 2015 Member of USF Tampa, Team 1-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G6
4 Members
6 Guides authored
3 Guide Comments
Looks like there is no procedure to explain how to put a new screen on there.
Lee - Reply
You don't need a Screen now. You have now successfully screwed your phone to a whopping 100%.
ranjit - Reply
Hello, I have unmounted my mi note pro to change the battery. I successfully changed it but now my phone's touch screen does not work anymore. The screen displays but the touch function doesn't work. Can someone help me identify the part I might have damaged or disconnected accidentally?
aimane786 - Reply
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 39
All Time: 16,319
