Xiaomi Mi Pad Headphone Jack Replacement
  1. Xiaomi Mi Pad Headphone Jack Replacement, Rear Case Assembly: step 1, image 1 of 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Headphone Jack Replacement: step 2, image 1 of 2 Xiaomi Mi Pad Headphone Jack Replacement: step 2, image 2 of 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: step 3, image 1 of 2 Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: step 3, image 2 of 2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Headphone Jack Replacement: step 4, image 1 of 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Headphone Jack Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to pull up and remove the headphone jack from the upper cover.
    • Insert the corner of a plastic opening tool into the port of the headphone jack for easier removal.
Rene Mendoza
311 Reputation
2 Guides authored
USF Tampa, Team 12-5, Blackwell Fall 2015 Member of USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Members
13 Guides authored
One Comment
And where to buy? :-(
marcusvoag - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 2,468
