Xiaomi Mi Pad Motherboard Replacement
  1. Xiaomi Mi Pad Motherboard Replacement, Rear Case Assembly: step 1, image 1 of 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Motherboard Replacement: step 2, image 1 of 2 Xiaomi Mi Pad Motherboard Replacement: step 2, image 2 of 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Motherboard Replacement, Motherboard: step 3, image 1 of 2 Xiaomi Mi Pad Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Remove the twelve 3 mm Phillips #00 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Motherboard Replacement: step 4, image 1 of 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Motherboard Replacement: step 5, image 1 of 1
    • Remove the two 3.0 mm Phillips #00 screws securing the motherboard to the device.
  6. Xiaomi Mi Pad Motherboard Replacement: step 6, image 1 of 2 Xiaomi Mi Pad Motherboard Replacement: step 6, image 2 of 2
    • Disconnect the six ribbon cables attached to the motherboard using a plastic opening tool.
  7. Xiaomi Mi Pad Motherboard Replacement: step 7, image 1 of 1
    • Carefully remove the motherboard from the device.
12 other people completed this guide.
Kiefer Sivitz
560 Reputation
3 Guides authored
USF Tampa, Team 12-5, Blackwell Fall 2015 Member of USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Members
13 Guides authored
4 Comments
It's my email
amaank987321.msk@gmail.com
MSK DIGITAL MEDIA - Reply
i'm looking to buy a motherboard for my died mi pad and i couldn't find it any were. Do you know were i can bay one , please help
Vasile Postolache - Reply
I want mi pad mother board
Where I buy
Sunil - Reply
where can i buy matherboard for Xiaomi Mi Pad 4 ?
guyv1975 - Reply
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 118
All Time: 7,330
