Xiaomi ROBOROCK S50200 Bottom Disassembly
  1. Xiaomi ROBOROCK S50200 Bottom Disassembly, Turning off the Roborock: step 1, image 1 of 2 Xiaomi ROBOROCK S50200 Bottom Disassembly, Turning off the Roborock: step 1, image 2 of 2
    • Turn off the device by pressing and holding the power button.
  2. Xiaomi ROBOROCK S50200 Bottom Disassembly, Remove the dustbin: step 2, image 1 of 1
    • Open the cover upwards.
    • Lift the dustbin upward to remove it.
  3. Xiaomi ROBOROCK S50200 Bottom Disassembly, Removing the main brush: step 3, image 1 of 2 Xiaomi ROBOROCK S50200 Bottom Disassembly, Removing the main brush: step 3, image 2 of 2
    • Remove the main brush holder by pressing both locks inward and lifting it up.
    • Remove the main brush.
  4. Xiaomi ROBOROCK S50200 Bottom Disassembly, Removing the side brush: step 4, image 1 of 3 Xiaomi ROBOROCK S50200 Bottom Disassembly, Removing the side brush: step 4, image 2 of 3 Xiaomi ROBOROCK S50200 Bottom Disassembly, Removing the side brush: step 4, image 3 of 3
    • Remove the screw holding the side brush.
    • You don't need to completely unscrew the screw; simply loosen it and remove it with the brush.
    • Remove the side brush along with the screw by lifting it upward.
  5. Xiaomi ROBOROCK S50200 Bottom Disassembly, Removing the front wheel.: step 5, image 1 of 3 Xiaomi ROBOROCK S50200 Bottom Disassembly, Removing the front wheel.: step 5, image 2 of 3 Xiaomi ROBOROCK S50200 Bottom Disassembly, Removing the front wheel.: step 5, image 3 of 3
    • Lift the front wheel with the screwdriver.
    • Completely pull the front wheel upward to remove it.
  6. Xiaomi ROBOROCK S50200 Bottom Disassembly, Remove the bottom panel: step 6, image 1 of 3 Xiaomi ROBOROCK S50200 Bottom Disassembly, Remove the bottom panel: step 6, image 2 of 3 Xiaomi ROBOROCK S50200 Bottom Disassembly, Remove the bottom panel: step 6, image 3 of 3
    • Remove the seven screws holding the bottom panel.
    • Lift the bottom cover up.
Repeat the steps in reverse order to reassemble the device.
Special thanks to these translators:
de en
100%
O.M. is helping us fix the world! Want to contribute?
Start translating ›
hainzy
5,673 Reputation
27 Guides authored
German Translators Member of German Translators
Community
28 Members
808 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 282
