Xiaomi ROBOROCK S50200 complete disassembly
  1. Xiaomi ROBOROCK S50200 complete disassembly, Turning off the Roborock: step 1, image 1 of 2 Xiaomi ROBOROCK S50200 complete disassembly, Turning off the Roborock: step 1, image 2 of 2
    • Turn off the device by pressing and holding the power button.
  2. Xiaomi ROBOROCK S50200 complete disassembly, Remove the dustbin: step 2, image 1 of 1
    • Open the cover upwards.
    • Lift the dustbin upward to remove it.
  3. Xiaomi ROBOROCK S50200 complete disassembly, Remove the front cover: step 3, image 1 of 2 Xiaomi ROBOROCK S50200 complete disassembly, Remove the front cover: step 3, image 2 of 2
    • Insert the spudger from the side
    • Release the clips by turning the spudger
    • Lift the cover upwards
    • These pictures show the front bumper already removed. This is not necessary for these instructions.
  4. Xiaomi ROBOROCK S50200 complete disassembly, Remove the dust container flap: step 4, image 1 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Remove the dust container flap: step 4, image 2 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Remove the dust container flap: step 4, image 3 of 3
    • Loosen the 6 screws for the hinges
    • Lift and remove the hinges
    • Remove the flap upwards
  5. Xiaomi ROBOROCK S50200 complete disassembly, Removing the laser cover: step 5, image 1 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Removing the laser cover: step 5, image 2 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Removing the laser cover: step 5, image 3 of 3
    • Remove the 5 screws for the cover
    • Remove the cover upwards
  6. Xiaomi ROBOROCK S50200 complete disassembly: step 6, image 1 of 2 Xiaomi ROBOROCK S50200 complete disassembly: step 6, image 2 of 2
    • Remove the 4 screws of the laser unit
    • Remove the unit upwards (unit is still plugged into the circuit board)
  7. Xiaomi ROBOROCK S50200 complete disassembly, Removing the main brush: step 7, image 1 of 2 Xiaomi ROBOROCK S50200 complete disassembly, Removing the main brush: step 7, image 2 of 2
    • Remove the main brush holder by pressing both locks inward and lifting it up.
    • Remove the main brush.
  8. Xiaomi ROBOROCK S50200 complete disassembly, Removing the side brush: step 8, image 1 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Removing the side brush: step 8, image 2 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Removing the side brush: step 8, image 3 of 3
    • Remove the screw holding the side brush.
    • You don't need to completely unscrew the screw; simply loosen it and remove it with the brush.
    • Remove the side brush along with the screw by lifting it upward.
  9. Xiaomi ROBOROCK S50200 complete disassembly, Removing the front wheel.: step 9, image 1 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Removing the front wheel.: step 9, image 2 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Removing the front wheel.: step 9, image 3 of 3
    • Lift the front wheel with the screwdriver.
    • Completely pull the front wheel upward to remove it.
  10. Xiaomi ROBOROCK S50200 complete disassembly, Remove the bottom panel: step 10, image 1 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Remove the bottom panel: step 10, image 2 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Remove the bottom panel: step 10, image 3 of 3
    • Remove the seven screws holding the bottom panel.
    • Lift the bottom cover up.
  11. Xiaomi ROBOROCK S50200 complete disassembly, Remove the battery: step 11, image 1 of 2 Xiaomi ROBOROCK S50200 complete disassembly, Remove the battery: step 11, image 2 of 2
    • Lift the battery using the two tabs.
    • Disconnect the connector.
  12. Xiaomi ROBOROCK S50200 complete disassembly, Remove the main brush assembly: step 12, image 1 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Remove the main brush assembly: step 12, image 2 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Remove the main brush assembly: step 12, image 3 of 3
    • Remove the four screws from the main brush assembly
    • Lift out the main brush assembly upwards
  13. Xiaomi ROBOROCK S50200 complete disassembly, Front bumper: step 13, image 1 of 2 Xiaomi ROBOROCK S50200 complete disassembly, Front bumper: step 13, image 2 of 2
    • Remove the 8 screws from the underside of the bumper
    • Remove the strip
    • Pull the bumper forwards, taking care not to bend the two metal plates
    • In the pictures another lip is mounted, which is not present in the original condition
    • The pictures show that the floor has already been removed, this is not necessary for this repair
  14. Xiaomi ROBOROCK S50200 complete disassembly, Side-brush motor: step 14, image 1 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Side-brush motor: step 14, image 2 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Side-brush motor: step 14, image 3 of 3
    • Remove the three screws from the motor
    • Pull the motor out upwards (plug connection with the circuit board)
  15. Xiaomi ROBOROCK S50200 complete disassembly, Remove the left wheel drive unit: step 15, image 1 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Remove the left wheel drive unit: step 15, image 2 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Remove the left wheel drive unit: step 15, image 3 of 3
    • remove the three screws from the drive unit
    • Remove wheel upwards (connected to a circuit board via plug connection)
  16. Xiaomi ROBOROCK S50200 complete disassembly, Right wheel: step 16, image 1 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Right wheel: step 16, image 2 of 3 Xiaomi ROBOROCK S50200 complete disassembly, Right wheel: step 16, image 3 of 3
    • Remove the three screws from the drive unit
    • Remove the wheel upwards (connected to the circuit board via a plug connection)
  17. Xiaomi ROBOROCK S50200 complete disassembly, Remove the top cover: step 17, image 1 of 2 Xiaomi ROBOROCK S50200 complete disassembly, Remove the top cover: step 17, image 2 of 2
    • Remove the 17 screws on the underside
Work through the steps in reverse order to reassemble your device
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
hainzy
5,673 Reputation
27 Guides authored
German Translators Member of German Translators
Community
28 Members
808 Guides authored
0 Comments
Past 24 Hours: 8
Past 7 Days: 50
Past 30 Days: 180
All Time: 1,464
