Xiaomi ROBOROCK S50200 side-brush motor repair
  1. Xiaomi ROBOROCK S50200 side-brush motor repair, Turning off the Roborock: step 1, image 1 of 2 Xiaomi ROBOROCK S50200 side-brush motor repair, Turning off the Roborock: step 1, image 2 of 2
    • Turn off the device by pressing and holding the power button.
  2. Xiaomi ROBOROCK S50200 side-brush motor repair, Remove the dustbin: step 2, image 1 of 1
    • Open the cover upwards.
    • Lift the dustbin upward to remove it.
  3. Xiaomi ROBOROCK S50200 side-brush motor repair, Removing the main brush: step 3, image 1 of 2 Xiaomi ROBOROCK S50200 side-brush motor repair, Removing the main brush: step 3, image 2 of 2
    • Remove the main brush holder by pressing both locks inward and lifting it up.
    • Remove the main brush.
  4. Xiaomi ROBOROCK S50200 side-brush motor repair, Removing the side brush: step 4, image 1 of 3 Xiaomi ROBOROCK S50200 side-brush motor repair, Removing the side brush: step 4, image 2 of 3 Xiaomi ROBOROCK S50200 side-brush motor repair, Removing the side brush: step 4, image 3 of 3
    • Remove the screw holding the side brush.
    • You don't need to completely unscrew the screw; simply loosen it and remove it with the brush.
    • Remove the side brush along with the screw by lifting it upward.
  5. Xiaomi ROBOROCK S50200 side-brush motor repair, Removing the front wheel.: step 5, image 1 of 3 Xiaomi ROBOROCK S50200 side-brush motor repair, Removing the front wheel.: step 5, image 2 of 3 Xiaomi ROBOROCK S50200 side-brush motor repair, Removing the front wheel.: step 5, image 3 of 3
    • Lift the front wheel with the screwdriver.
    • Completely pull the front wheel upward to remove it.
  6. Xiaomi ROBOROCK S50200 side-brush motor repair, Remove the bottom panel: step 6, image 1 of 3 Xiaomi ROBOROCK S50200 side-brush motor repair, Remove the bottom panel: step 6, image 2 of 3 Xiaomi ROBOROCK S50200 side-brush motor repair, Remove the bottom panel: step 6, image 3 of 3
    • Remove the seven screws holding the bottom panel.
    • Lift the bottom cover up.
  7. Xiaomi ROBOROCK S50200 side-brush motor repair, Side-brush motor: step 7, image 1 of 3 Xiaomi ROBOROCK S50200 side-brush motor repair, Side-brush motor: step 7, image 2 of 3 Xiaomi ROBOROCK S50200 side-brush motor repair, Side-brush motor: step 7, image 3 of 3
    • Remove the three screws from the motor
    • Pull the motor out upwards (plug connection with the circuit board)
Work through the steps in reverse order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
hainzy
7,576 Reputation
40 Guides authored
Made in Germany Member of Made in Germany
Community
38 Members
1,459 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 865
