Xiaomi Redmi 2 Ambient Light Sensor Replacement
  1. Xiaomi Redmi 2 Ambient Light Sensor Replacement, Motherboard: step 1, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement, Motherboard: step 1, image 2 of 2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 2, image 1 of 1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 3, image 1 of 1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 4, image 1 of 1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 5, image 1 of 1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 6, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 7, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 7, image 2 of 2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 8, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 8, image 2 of 2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 9, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 9, image 2 of 2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 10, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 10, image 2 of 2
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 11, image 1 of 1
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Ambient Light Sensor Replacement, Ambient Light Sensor: step 12, image 1 of 1
    Buy
    • Using one prong of the tweezers, lift and loosen the edge of the ambient light sensor from the motherboard.
  13. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 13, image 1 of 1
    • Using your fingers, gently pull out the ambient light sensor.
17 other people completed this guide.
Alicia Brenner
3,539 Reputation
5 Guides authored
USF Tampa, Team 1-3, Leahy Fall 2015 Member of USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
2 Members
5 Guides authored
One Comment
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 5,287
