Xiaomi Redmi 2 Motherboard Replacement
  1. Xiaomi Redmi 2 Motherboard Replacement, Motherboard: step 1, image 1 of 2 Xiaomi Redmi 2 Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Motherboard Replacement: step 2, image 1 of 1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Motherboard Replacement: step 3, image 1 of 1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Motherboard Replacement: step 4, image 1 of 1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Motherboard Replacement: step 5, image 1 of 1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Motherboard Replacement: step 6, image 1 of 2 Xiaomi Redmi 2 Motherboard Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Motherboard Replacement: step 7, image 1 of 2 Xiaomi Redmi 2 Motherboard Replacement: step 7, image 2 of 2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Motherboard Replacement: step 8, image 1 of 2 Xiaomi Redmi 2 Motherboard Replacement: step 8, image 2 of 2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Motherboard Replacement: step 9, image 1 of 2 Xiaomi Redmi 2 Motherboard Replacement: step 9, image 2 of 2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Motherboard Replacement: step 10, image 1 of 2 Xiaomi Redmi 2 Motherboard Replacement: step 10, image 2 of 2
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Motherboard Replacement: step 11, image 1 of 1
    • Lift the motherboard out of the front cover and set aside.
46 other people completed this guide.
Alicia Brenner
3,539 Reputation
5 Guides authored
USF Tampa, Team 1-3, Leahy Fall 2015 Member of USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
2 Members
5 Guides authored
17 Comments
this is very helpful
Ana - Reply
hi brother mi phone was water damaged .it was not wrking i mean phone gets on but no display. phone gets ring and i can lift call and speak. when i connect to laptop i can access files in it. its get charging on connecting to charger
can u suggest me wat to do
please
asreefbashak - Reply
may be LCD is damage. can fix it at 82877181 contact Peter for checking.
netman91 -
Hi bro I'm having redmi 2 mobile and it has a problem it is not taking any os it's having a compliant of not receiving os .....
There is any solution for that
Please give me reply bro any suggestions
jhon Carter - Reply
Can i know the name of the motherboard used for redmi 2 prime 16GB,please tell me the name bro
Jakka Akhilesh - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 31
All Time: 35,064
