Xiaomi Redmi Note 10 Pro Screen Replacement
  1. Xiaomi Redmi Note 10 Pro Screen Replacement, Eject the SIM card tray: step 1, image 1 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Eject the SIM card tray: step 1, image 2 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Eject the SIM card tray: step 1, image 3 of 3
    • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Xiaomi Redmi Note 10 Pro Screen Replacement, Heat the rear glass: step 2, image 1 of 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Xiaomi Redmi Note 10 Pro Screen Replacement, Secure a suction handle: step 3, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement, Secure a suction handle: step 3, image 2 of 2
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • The surface of the rear glass is not completely smooth. For a better grip of the suction handle, apply tape to the rear glass or moisten the suction handle.
    • Secure a suction handle to the right edge of the rear glass, as close to the edge as possible.
  4. Xiaomi Redmi Note 10 Pro Screen Replacement, Create a gap: step 4, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement, Create a gap: step 4, image 2 of 2
    • Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  5. Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 5, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 5, image 2 of 2
    • Slide the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 6, image 1 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 6, image 2 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 6, image 3 of 3
    • Insert a second opening pick next to the top right corner.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  7. Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 7, image 1 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 7, image 2 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 7, image 3 of 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  8. Xiaomi Redmi Note 10 Pro Screen Replacement: step 8, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement: step 8, image 2 of 2
    • Insert a fourth opening pick underneath the bottom left corner of your phone.
    • Slide the opening pick up to the volume button.
    • Don't slide the opening pick any further! A flex cable runs next to the volume button.
  9. Xiaomi Redmi Note 10 Pro Screen Replacement: step 9, image 1 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement: step 9, image 2 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement: step 9, image 3 of 3
    • Insert a sixth opening pick at the left edge of your phone next to the top end of the power and volume button cut out.
    • Slice the remaining adhesive of the left edge.
    • Slide the opening pick around the top left corner and along the top edge to cut the remaining adhesive.
  10. Xiaomi Redmi Note 10 Pro Screen Replacement, Remove the rear glass: step 10, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement, Remove the rear glass: step 10, image 2 of 2
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  11. Xiaomi Redmi Note 10 Pro Screen Replacement, Unscrew the midframe: step 11, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement, Unscrew the midframe: step 11, image 2 of 2
    • Use a Phillips screwdriver to remove the seventeen screws securing the midframe:
    • Nine 4.4 mm-long screws in the upper area of the midframe
    • Eight 3.4 mm-long screws in the lower area of the midframe
  12. Xiaomi Redmi Note 10 Pro Screen Replacement, Insert an opening pick: step 12, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement, Insert an opening pick: step 12, image 2 of 2
    • The midframe is held in place by plastic clips.
    • Insert an opening pick between the midframe and front panel assembly on the bottom of the phone near the charging port.
    • Slide the opening pick to the bottom left corner to release the plastic clips.
  13. Xiaomi Redmi Note 10 Pro Screen Replacement, Release the plastic clips: step 13, image 1 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Release the plastic clips: step 13, image 2 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Release the plastic clips: step 13, image 3 of 3
    • Slide the opening pick along the left edge of your phone to release the plastic clips.
  14. Xiaomi Redmi Note 10 Pro Screen Replacement: step 14, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement: step 14, image 2 of 2
    • Slide the opening pick along the top edge to release the plastic clips.
  15. Xiaomi Redmi Note 10 Pro Screen Replacement: step 15, image 1 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement: step 15, image 2 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement: step 15, image 3 of 3
    • Slide the opening pick along the right edge to release the remaining plastic clips.
    • Don't try to remove the midframe all the way yet! The side buttons are still connected to the motherboard by a flex cable.
  16. Xiaomi Redmi Note 10 Pro Screen Replacement, Swing open the midframe: step 16, image 1 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Swing open the midframe: step 16, image 2 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Swing open the midframe: step 16, image 3 of 3
    • Avoid straining the side button flex cable in the following step!
    • Carefully swing the midframe open in the direction of the power and volume buttons and place the midframe close to the phone assembly.
  17. Xiaomi Redmi Note 10 Pro Screen Replacement, Disconnect the power and volume button flex cable: step 17, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement, Disconnect the power and volume button flex cable: step 17, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the power and volume button flex cable from the motherboard.
  18. Xiaomi Redmi Note 10 Pro Screen Replacement, Remove the midframe: step 18, image 1 of 1
    • Remove the midframe.
  19. Xiaomi Redmi Note 10 Pro Screen Replacement, Disconnect the battery cable: step 19, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement, Disconnect the battery cable: step 19, image 2 of 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  20. Xiaomi Redmi Note 10 Pro Screen Replacement, Disconnect the display flex cable: step 20, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement, Disconnect the display flex cable: step 20, image 2 of 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  21. Xiaomi Redmi Note 10 Pro Screen Replacement, Loosen the display adhesive: step 21, image 1 of 1
    • Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  22. Xiaomi Redmi Note 10 Pro Screen Replacement, Create a gap: step 22, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement, Create a gap: step 22, image 2 of 2
    • Once the screen is warm to touch, apply a suction cup to the left edge of the phone.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the midframe.
    • Insert an opening pick in the gap between the midframe and the screen.
  23. Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 23, image 1 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 23, image 2 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 23, image 3 of 3
    • Slide the opening pick to the bottom left corner of the screen to slice its adhesive.
  24. Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 24, image 1 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 24, image 2 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 24, image 3 of 3
    • Insert a second opening pick and slide it to the top left corner of the screen to cut the adhesive.
  25. Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 25, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement, Slice the adhesive: step 25, image 2 of 2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the bottom edge of the screen to slice the adhesive.
    • Leave it in the bottom right corner to prevent the adhesive from resealing.
  26. Xiaomi Redmi Note 10 Pro Screen Replacement: step 26, image 1 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement: step 26, image 2 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement: step 26, image 3 of 3
    • Insert a fourth opening pick at the bottom right corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner of the screen to prevent the adhesive from resealing.
  27. Xiaomi Redmi Note 10 Pro Screen Replacement: step 27, image 1 of 2 Xiaomi Redmi Note 10 Pro Screen Replacement: step 27, image 2 of 2
    • When you slice near the front facing camera, insert only the tip of the opening pick to avoid damaging or smearing the camera.
    • Insert a fifth opening pick and slide it along the top edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the display cable is still threaded through the frame.
  28. Xiaomi Redmi Note 10 Pro Screen Replacement, Free the screen: step 28, image 1 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Free the screen: step 28, image 2 of 3 Xiaomi Redmi Note 10 Pro Screen Replacement, Free the screen: step 28, image 3 of 3
    • Thread the display flex cable through the gap in the midframe.
  29. Xiaomi Redmi Note 10 Pro Screen Replacement, Remove the screen: step 29, image 1 of 1
    • Remove the screen.
    • Compare your new replacement part to the original part—you may need to transfer remaining components like the speaker grill from your old screen to your new screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
24 other people completed this guide.
Adriana Zwink
63,423 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,977 Guides authored
5 Guide Comments
Awesome, thanks!
I M - Reply
Please where do I get a quality replacement screen with international shipping.
Bamigbade Abdulazeez - Reply
Qualitiy is difficult, but maybe give Aliexpress a shot, at least you can get a display there. But I doubt that you will find one of similar quality than the original one.
Firestar1291 -
Hello, I have a doubt.
The placement of the display connector and even the connector itself are very very similar to the ones found on the Samsung A71 A715F
I have both this phone and the Samsung A71 A715F. This gave me the doubt weather I can use the display from the Samsung on the other phone. What do you guys think?
Rohan Koganti - Reply
I was never able to remove the midframe, although all the clips around the edges had released. It felt like it was stuck around the camera area (glued?) and the amount of force necessary to pull it apart would have meant that something would break.
NiclasE - Reply
Past 24 Hours: 21
Past 7 Days: 178
Past 30 Days: 786
All Time: 34,715
