Xiaomi Redmi Note 10S Back Cover Replacement
  1. Xiaomi Redmi Note 10S Back Cover Replacement, Heat the back cover: step 1, image 1 of 1
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Xiaomi Redmi Note 10S Back Cover Replacement, Insert an opening pick: step 2, image 1 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Insert an opening pick: step 2, image 2 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Insert an opening pick: step 2, image 3 of 3
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 3, image 1 of 2 Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 3, image 2 of 2
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 4, image 1 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 4, image 2 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 4, image 3 of 3
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    • You can remove the suction cup now.
  5. Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 5, image 1 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 5, image 2 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 5, image 3 of 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 6, image 1 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 6, image 2 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 6, image 3 of 3
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 7, image 1 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 7, image 2 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Slice the adhesive: step 7, image 3 of 3
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
  8. Xiaomi Redmi Note 10S Back Cover Replacement, Remove the back cover: step 8, image 1 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Remove the back cover: step 8, image 2 of 3 Xiaomi Redmi Note 10S Back Cover Replacement, Remove the back cover: step 8, image 3 of 3
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Manuel Haeussermann
16,286 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,085 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 49
Past 30 Days: 203
All Time: 1,782
