Xiaomi Redmi Note 11 Pro Screen Replacement
  1. Xiaomi Redmi Note 11 Pro Screen Replacement, Heat the rear glass: step 1, image 1 of 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Xiaomi Redmi Note 11 Pro Screen Replacement, Insert an opening pick: step 2, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Insert an opening pick: step 2, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Insert an opening pick: step 2, image 3 of 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • If you're having trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Xiaomi Redmi Note 11 Pro Screen Replacement, Slice the bottom edge adhesive: step 3, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Slice the bottom edge adhesive: step 3, image 2 of 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Redmi Note 11 Pro Screen Replacement, Slice the left edge adhesive: step 4, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Slice the left edge adhesive: step 4, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Slice the left edge adhesive: step 4, image 3 of 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Redmi Note 11 Pro Screen Replacement: step 5, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement: step 5, image 2 of 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 11 Pro Screen Replacement: step 6, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement: step 6, image 2 of 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    • At this point, the rear glass should be separated from the frame. If there's still resistance around the edges of the glass, use an opening pick to separate any remaining adhesive.
  7. Xiaomi Redmi Note 11 Pro Screen Replacement, Remove the rear glass: step 7, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Remove the rear glass: step 7, image 2 of 2
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. Xiaomi Redmi Note 11 Pro Screen Replacement, Eject the SIM card tray: step 8, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Eject the SIM card tray: step 8, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Eject the SIM card tray: step 8, image 3 of 3
    • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the bottom edge of the phone.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  9. Xiaomi Redmi Note 11 Pro Screen Replacement, Unfasten the midframe screws: step 9, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Unfasten the midframe screws: step 9, image 2 of 2
    • Use a Phillips screwdriver to remove the seventeen 3.6 mm-long screws securing the midframe.
  10. Xiaomi Redmi Note 11 Pro Screen Replacement, Insert an opening pick: step 10, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Insert an opening pick: step 10, image 2 of 2
    • The midframe of the Xiaomi Redmi Note 11 Pro is held in place by plastic clips.
    • Insert an opening pick between the midframe and front panel assembly on the bottom left edge of the phone where the SIM tray slot is located.
  11. Xiaomi Redmi Note 11 Pro Screen Replacement, Release the plastic clips: step 11, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Release the plastic clips: step 11, image 2 of 2
    • The plastic clips of the midframe are sitting in place tightly. Releasing them might require some force.
    • Slide the opening pick around the bottom left corner of the phone to release the plastic clips.
  12. Xiaomi Redmi Note 11 Pro Screen Replacement: step 12, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement: step 12, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement: step 12, image 3 of 3
    • Slide the opening pick along the left edge of the phone to release the plastic clips.
  13. Xiaomi Redmi Note 11 Pro Screen Replacement: step 13, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement: step 13, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement: step 13, image 3 of 3
    • Slide the opening pick around the top left corner and along the top edge of the phone to release the plastic clips.
  14. Xiaomi Redmi Note 11 Pro Screen Replacement: step 14, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement: step 14, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement: step 14, image 3 of 3
    • Slide the opening pick around the top right corner and along the right edge of the phone to release the remaining plastic clips.
    • Do not try to remove the midframe all the way yet. The midframe cable is still connected to the motherboard.
  15. Xiaomi Redmi Note 11 Pro Screen Replacement, Free the midframe cable connector: step 15, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Free the midframe cable connector: step 15, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Free the midframe cable connector: step 15, image 3 of 3
    • Carefully swing open the midframe to the left like you would open the front cover of a book to get free access to its cable connector.
    • Place the midframe next to the left edge of the front panel assembly.
  16. Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the midframe cable: step 16, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the midframe cable: step 16, image 2 of 2
    • Use a spudger to disconnect the midframe cable by prying the connector straight up from its socket.
  17. Xiaomi Redmi Note 11 Pro Screen Replacement, Remove the midframe: step 17, image 1 of 1
    • Remove the midframe.
  18. Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the battery cables: step 18, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the battery cables: step 18, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the battery cables: step 18, image 3 of 3
    • Use a spudger to disconnect the left and right battery cable by prying the connectors straight up from their socket.
  19. Xiaomi Redmi Note 11 Pro Screen Replacement, Unfasten the loudspeaker screw: step 19, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Unfasten the loudspeaker screw: step 19, image 2 of 2
    • Use a Phillips screwdriver to remove the 3.6 mm-long screw securing the loudspeaker.
  20. Xiaomi Redmi Note 11 Pro Screen Replacement, Pry up the loudspeaker: step 20, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Pry up the loudspeaker: step 20, image 2 of 2
    • The loudspeaker of the Xiaomi Redmi Note 11 Pro is held in place by plastic clips.
    • Insert an spudger underneath the right edge of the loudspeaker.
    • Use your spudger to pry up the loudspeaker.
  21. Xiaomi Redmi Note 11 Pro Screen Replacement, Remove the loudspeaker: step 21, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Remove the loudspeaker: step 21, image 2 of 2
    Tool used on this step:
    Buy
    • Use your fingers or a pair of tweezers to remove the loudspeaker.
  22. Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the black antenna cable: step 22, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the black antenna cable: step 22, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the black antenna cable: step 22, image 3 of 3
    Buy
    • Slide a pair of tweezers under the black coaxial cable until they're snug against the metal connector.
    • Disconnect the black coaxial cable by prying it straight up from the charging board.
    • Use your tweezers to carefully loosen the cable from its routing on the charging board and bend it to the side.
  23. Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the interconnect cable: step 23, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the interconnect cable: step 23, image 2 of 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  24. Xiaomi Redmi Note 11 Pro Screen Replacement, Pry up the charging board: step 24, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Pry up the charging board: step 24, image 2 of 2
    • Insert the pointed end of a spudger underneath the left edge of the charging board.
    • Use your spudger to pry up the charging board.
  25. Xiaomi Redmi Note 11 Pro Screen Replacement, Remove the charging board: step 25, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Remove the charging board: step 25, image 2 of 2
    • Use a pair of tweezers of your fingers to carefully remove the charging board.
  26. Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the display cable: step 26, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Disconnect the display cable: step 26, image 2 of 2
    • Use a spudger to disconnect the display cable by prying the connector straight up from its socket.
  27. Xiaomi Redmi Note 11 Pro Screen Replacement, Loosen the display adhesive: step 27, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Loosen the display adhesive: step 27, image 2 of 2
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 5 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    • Since the rear cameras of the Xiaomi Redmi Note 11 Pro protrude slightly above the frame, you can place a lint-free cloth underneath to avoid damaging them during the display removal procedure.
  28. Xiaomi Redmi Note 11 Pro Screen Replacement, Insert an opening pick: step 28, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Insert an opening pick: step 28, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Insert an opening pick: step 28, image 3 of 3
    • Once the screen is warm to touch, apply a suction handle to the top edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the midframe and the screen, at the left side of the earpiece speaker cut-out.
    • Slide the opening pick to the top left corner of the screen to slice its adhesive.
  29. Xiaomi Redmi Note 11 Pro Screen Replacement, Slice the adhesive: step 29, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement, Slice the adhesive: step 29, image 2 of 2
    • Insert a second opening pick into the gap between the midframe and the screen at the left side of the earpiece speaker cut-out.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2–3 mm) to avoid damaging or smearing the camera.
    • Slide the opening pick to the top right corner of the screen to slice its adhesive.
  30. Xiaomi Redmi Note 11 Pro Screen Replacement: step 30, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement: step 30, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement: step 30, image 3 of 3
    • Insert a third opening pick at the top right corner of the screen.
    • Slide the opening pick along the right edge of the phone to slice the adhesive.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
  31. Xiaomi Redmi Note 11 Pro Screen Replacement: step 31, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement: step 31, image 2 of 2
    • Insert a fourth opening pick underneath the bottom right corner of the screen.
    • Slide the opening pick along the bottom edge of the screen to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  32. Xiaomi Redmi Note 11 Pro Screen Replacement: step 32, image 1 of 2 Xiaomi Redmi Note 11 Pro Screen Replacement: step 32, image 2 of 2
    • Insert a fifth opening pick at the bottom left corner of the screen.
    • Slide the opening pick along the left edge to slice the remaining adhesive.
    • Do not try to remove the display all the way yet. The display cable is still threaded through the frame.
  33. Xiaomi Redmi Note 11 Pro Screen Replacement, Remove the screen: step 33, image 1 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Remove the screen: step 33, image 2 of 3 Xiaomi Redmi Note 11 Pro Screen Replacement, Remove the screen: step 33, image 3 of 3
    • Carefully thread the display cable through the gap in the midframe.
    • Remove the screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
21 other people completed this guide.
Dominik Schnabelrauch
250,040 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,996 Guides authored
8 Guide Comments
I used this guide to replace screen on non-Pro version and it worked fine. Thank you!
Dmytro Y. - Reply
This really helped me replace a screen for the regular redmi note 11.
Michiel Mariën - Reply
Habe mein Note 11s mithilfe dieser Anleitung als Referenz wieder nutzbar gemacht :)
Hat zwar nun nur noch VGA Display anstatt Amoled - aber als Fahrrad-Navigation oder Notfall-Ersatz-Gerät wird es ausreichend sein.
Ich bin zumindest froh dass es wieder nutzbar ist.
Danke für die Anleitung und Übersetzung.
PS: beim 11s ist eine Schraube weniger verbaut und das Layout der Schrauben geringfügig anders.
Zwei. Der Schrauben verstecken sich unter dem Kamerglaskörper der Separat vom Rahmen genommen werden muss (das 11s hat eine Kunststoffrückseite)
PfeifferCh - Reply
For my non-pro Note 11 I bought the replacement screen that comes with a l frame because I thought it must be easier to replace, but apparently there's no guide for that procedure. It says here that it's a very different process, so I'm hesitant to try. Any pointers you can give me to good instructions for that?
Tamar Opher - Reply
Did you find something? I just bought a replacement screen with frame for my non-pro Note 11S. Once it's here I'm just going to try using this guide, unless there's something better available somewhere? I've only skimmed the guide now, will wait for the display to arrive before taking a closer look.
Carl von Randow -
Past 24 Hours: 33
Past 7 Days: 177
Past 30 Days: 700
All Time: 28,324
