Xiaomi Redmi Note 8T Battery Disconnect
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Xiaomi Redmi Note 8T Battery Disconnect, Xiaomi Redmi Note 8T Rear Glass Removal: step 1, image 1 of 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Xiaomi Redmi Note 8T Battery Disconnect: step 2, image 1 of 3 Xiaomi Redmi Note 8T Battery Disconnect: step 2, image 2 of 3 Xiaomi Redmi Note 8T Battery Disconnect: step 2, image 3 of 3
    • Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Xiaomi Redmi Note 8T Battery Disconnect: step 3, image 1 of 2 Xiaomi Redmi Note 8T Battery Disconnect: step 3, image 2 of 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    • Don't remove the suction handle yet. You're going to use it later in the removal procedure as a rear glass stand.
  4. Xiaomi Redmi Note 8T Battery Disconnect: step 4, image 1 of 3 Xiaomi Redmi Note 8T Battery Disconnect: step 4, image 2 of 3 Xiaomi Redmi Note 8T Battery Disconnect: step 4, image 3 of 3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Redmi Note 8T Battery Disconnect: step 5, image 1 of 2 Xiaomi Redmi Note 8T Battery Disconnect: step 5, image 2 of 2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 8T Battery Disconnect: step 6, image 1 of 2 Xiaomi Redmi Note 8T Battery Disconnect: step 6, image 2 of 2
    • Do not insert the opening pick deeper than 5 mm to avoid damaging the fingerprint connector.
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
    • Do not remove the rear glass all the way yet, the fingerprint cable is still connected to the motherboard.
  7. Xiaomi Redmi Note 8T Battery Disconnect: step 7, image 1 of 2 Xiaomi Redmi Note 8T Battery Disconnect: step 7, image 2 of 2
    • Carefully fold the rear glass to the right side of the phone. Use the suction handle as a stand for the rear glass.
  8. Xiaomi Redmi Note 8T Battery Disconnect: step 8, image 1 of 2 Xiaomi Redmi Note 8T Battery Disconnect: step 8, image 2 of 2
    • Use a spudger to pry up and disconnect the fingerprint flex cable.
    • Remove the rear glass.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  9. Careful: steps 9-11 are sourced from a guide that's marked as in-progress.
    Xiaomi Redmi Note 8T Battery Disconnect, Xiaomi Redmi Note 8T Motherboard Cover Removal: step 9, image 1 of 1
    • Remove the eleven Phillips #00 screws (3.9 mm length).
  10. Xiaomi Redmi Note 8T Battery Disconnect: step 10, image 1 of 2 Xiaomi Redmi Note 8T Battery Disconnect: step 10, image 2 of 2
    • Insert the tip of an opening pick underneath the bottom edge of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  11. Xiaomi Redmi Note 8T Battery Disconnect: step 11, image 1 of 2 Xiaomi Redmi Note 8T Battery Disconnect: step 11, image 2 of 2
    • Remove the motherboard cover including the black protective foil that covers the battery.
  12. Xiaomi Redmi Note 8T Battery Disconnect, Xiaomi Redmi Note 8T Battery Disconnect: step 12, image 1 of 2 Xiaomi Redmi Note 8T Battery Disconnect, Xiaomi Redmi Note 8T Battery Disconnect: step 12, image 2 of 2
    • Use a spudger to pry up and disconnect the battery flex cable.
2 other people completed this guide.
Dominik Schnabelrauch
211,821 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,079 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 234
