Xiaomi Redmi Note 9S Rear Glass Replacement
  1. Xiaomi Redmi Note 9S Rear Glass Replacement, Heat the rear glass: step 1, image 1 of 1
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Xiaomi Redmi Note 9S Rear Glass Replacement, Insert an opening pick: step 2, image 1 of 3 Xiaomi Redmi Note 9S Rear Glass Replacement, Insert an opening pick: step 2, image 2 of 3 Xiaomi Redmi Note 9S Rear Glass Replacement, Insert an opening pick: step 2, image 3 of 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Xiaomi Redmi Note 9S Rear Glass Replacement, Slice the adhesive: step 3, image 1 of 2 Xiaomi Redmi Note 9S Rear Glass Replacement, Slice the adhesive: step 3, image 2 of 2
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Xiaomi Redmi Note 9S Rear Glass Replacement, Slice the adhesive: step 4, image 1 of 3 Xiaomi Redmi Note 9S Rear Glass Replacement, Slice the adhesive: step 4, image 2 of 3 Xiaomi Redmi Note 9S Rear Glass Replacement, Slice the adhesive: step 4, image 3 of 3
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Xiaomi Redmi Note 9S Rear Glass Replacement: step 5, image 1 of 3 Xiaomi Redmi Note 9S Rear Glass Replacement: step 5, image 2 of 3 Xiaomi Redmi Note 9S Rear Glass Replacement: step 5, image 3 of 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 9S Rear Glass Replacement: step 6, image 1 of 3 Xiaomi Redmi Note 9S Rear Glass Replacement: step 6, image 2 of 3 Xiaomi Redmi Note 9S Rear Glass Replacement: step 6, image 3 of 3
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. Xiaomi Redmi Note 9S Rear Glass Replacement: step 7, image 1 of 3 Xiaomi Redmi Note 9S Rear Glass Replacement: step 7, image 2 of 3 Xiaomi Redmi Note 9S Rear Glass Replacement: step 7, image 3 of 3
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
  8. Xiaomi Redmi Note 9S Rear Glass Replacement, Remove the rear glass: step 8, image 1 of 2 Xiaomi Redmi Note 9S Rear Glass Replacement, Remove the rear glass: step 8, image 2 of 2
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
Manuel Haeussermann
16,286 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,077 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 52
All Time: 734
