Xiaomi Redmi Note Battery Replacement
  1. Xiaomi Redmi Note Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Battery Replacement: step 2, image 1 of 2 Xiaomi Redmi Note Battery Replacement: step 2, image 2 of 2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Battery Replacement: step 3, image 1 of 2 Xiaomi Redmi Note Battery Replacement: step 3, image 2 of 2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
6 other people completed this guide.
Slater Stewart
282 Reputation
1 Guide authored
Cal Poly, Team S22-G4, Livingston Spring 2017 Member of Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Members
16 Guides authored
3 Guide Comments
Geht das so einfach auch bei Redmi note 7 ???
Ingeborg Langer - Reply
Ich fürchte nein, sie ist als “nicht entfernbar" beschrieben.
VauWeh -
Wie sieht es beim Redmi Note 11 S aus?
Schlotti P. - Reply
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 84
All Time: 15,794
