Xiaomi Redmi Note Front-Facing Camera Replacement
  1. Xiaomi Redmi Note Front-Facing Camera Replacement, Battery: step 1, image 1 of 1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Front-Facing Camera Replacement: step 2, image 1 of 2 Xiaomi Redmi Note Front-Facing Camera Replacement: step 2, image 2 of 2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Front-Facing Camera Replacement: step 3, image 1 of 2 Xiaomi Redmi Note Front-Facing Camera Replacement: step 3, image 2 of 2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: step 4, image 1 of 2 Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: step 4, image 2 of 2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Front-Facing Camera Replacement: step 5, image 1 of 2 Xiaomi Redmi Note Front-Facing Camera Replacement: step 5, image 2 of 2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: step 6, image 1 of 3 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: step 6, image 2 of 3 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
2 other people completed this guide.
Caitlin Settles
738 Reputation
2 Guides authored
Cal Poly, Team S22-G4, Livingston Spring 2017 Member of Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 33
All Time: 1,435
