Xiaomi Redmi Note Rear Camera Replacement
  1. Xiaomi Redmi Note Rear Camera Replacement, Battery: step 1, image 1 of 1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Rear Camera Replacement: step 2, image 1 of 2 Xiaomi Redmi Note Rear Camera Replacement: step 2, image 2 of 2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Rear Camera Replacement: step 3, image 1 of 2 Xiaomi Redmi Note Rear Camera Replacement: step 3, image 2 of 2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Rear Camera Replacement, Midframe: step 4, image 1 of 2 Xiaomi Redmi Note Rear Camera Replacement, Midframe: step 4, image 2 of 2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Rear Camera Replacement: step 5, image 1 of 2 Xiaomi Redmi Note Rear Camera Replacement: step 5, image 2 of 2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Rear Camera Replacement, Rear Camera: step 6, image 1 of 2 Xiaomi Redmi Note Rear Camera Replacement, Rear Camera: step 6, image 2 of 2
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
4 other people completed this guide.
AJ Beers
213 Reputation
2 Guides authored
Cal Poly, Team S22-G4, Livingston Spring 2017 Member of Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 4,080
