Xiaomi Yi Front Panel Replacement
  1. Xiaomi Yi Front Panel Replacement, Battery: step 1, image 1 of 2 Xiaomi Yi Front Panel Replacement, Battery: step 1, image 2 of 2
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Front Panel Replacement: step 2, image 1 of 3 Xiaomi Yi Front Panel Replacement: step 2, image 2 of 3 Xiaomi Yi Front Panel Replacement: step 2, image 3 of 3
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Front Panel Replacement, Front Panel: step 3, image 1 of 2 Xiaomi Yi Front Panel Replacement, Front Panel: step 3, image 2 of 2
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Front Panel Replacement: step 4, image 1 of 3 Xiaomi Yi Front Panel Replacement: step 4, image 2 of 3 Xiaomi Yi Front Panel Replacement: step 4, image 3 of 3
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
5 other people completed this guide.
William Zipperer
711 Reputation
3 Guides authored
USF Tampa, Team 15-5, Blackwell Fall 2015 Member of USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
3 Members
10 Guides authored
3 Comments
Where do you get a spare front panel, the small plastic hooks break easily
ltkipras - Reply
I would like to know too because i had a crash and i lost the ring that goes around the lens.
fabiocastroam -
For what is the black Strip with the gold plated contact on the front panel? Is that a check for installated front panel, and can i fake them for an replacement panel?
shguro - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 2,875
