XtremeMac Luna Button Circuit Boards Replacement
  1. XtremeMac Luna Button Circuit Boards Replacement, Bottom Panel: step 1, image 1 of 3 XtremeMac Luna Button Circuit Boards Replacement, Bottom Panel: step 1, image 2 of 3 XtremeMac Luna Button Circuit Boards Replacement, Bottom Panel: step 1, image 3 of 3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Button Circuit Boards Replacement: step 2, image 1 of 1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Button Circuit Boards Replacement: step 3, image 1 of 2 XtremeMac Luna Button Circuit Boards Replacement: step 3, image 2 of 2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. XtremeMac Luna Button Circuit Boards Replacement, Dock Circuit Board: step 4, image 1 of 3 XtremeMac Luna Button Circuit Boards Replacement, Dock Circuit Board: step 4, image 2 of 3 XtremeMac Luna Button Circuit Boards Replacement, Dock Circuit Board: step 4, image 3 of 3
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
  5. XtremeMac Luna Button Circuit Boards Replacement, Button Circuit Boards: step 5, image 1 of 2 XtremeMac Luna Button Circuit Boards Replacement, Button Circuit Boards: step 5, image 2 of 2
    • Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
    • Removing the right circuit board first will make it easier to unscrew the left because the heat-sinks on the left circuit board can get in the way of the screwdriver.
  6. XtremeMac Luna Button Circuit Boards Replacement: step 6, image 1 of 3 XtremeMac Luna Button Circuit Boards Replacement: step 6, image 2 of 3 XtremeMac Luna Button Circuit Boards Replacement: step 6, image 3 of 3
    • Use a plastic opening tool to pry the black connections away from the top casing.
    • Be attentive when you separate the circuit boards from the top, as there is a loose wheel inside.
  7. XtremeMac Luna Button Circuit Boards Replacement: step 7, image 1 of 2 XtremeMac Luna Button Circuit Boards Replacement: step 7, image 2 of 2
    • Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs.
    • The glue that holds the connection together will come off when you pull. Pull on the tab with enough force to break the glue without damaging the wires.
Andre Rivera
8 Reputation
1 Guide authored
Cal Poly, Team 3-47, Amido Spring 2013 Member of Cal Poly, Team 3-47, Amido Spring 2013
CPSU-AMIDO-S13S3G47
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 339
