Yamaha NS-AW190BL Input/Output Panel Replacement
  1. Yamaha NS-AW190BL Input/Output Panel Replacement, Input/Output Panel: step 1, image 1 of 2 Yamaha NS-AW190BL Input/Output Panel Replacement, Input/Output Panel: step 1, image 2 of 2
    • Remove all four .5 mm Phillips head screws located on the back panel of the device.
    • Pull out the input/output panel from the back of the device once all four screws are removed.
  2. Yamaha NS-AW190BL Input/Output Panel Replacement: step 2, image 1 of 3 Yamaha NS-AW190BL Input/Output Panel Replacement: step 2, image 2 of 3 Yamaha NS-AW190BL Input/Output Panel Replacement: step 2, image 3 of 3
    • Gently push down on the tab holding the connectors together.
    • Repeat the process on the second connector. (Even though they appear different, they are held together using the same tabs.)
    • Remove both connectors to free the input/output panel.
bradley
101 Reputation
1 Guide authored
USF Tampa, Team 17-3, Blackwell Spring 2017 Member of USF Tampa, Team 17-3, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 673
