Yamaha NS-AW190BL Rear Casing Replacement
  1. Yamaha NS-AW190BL Rear Casing Replacement, Rear Casing: step 1, image 1 of 2 Yamaha NS-AW190BL Rear Casing Replacement, Rear Casing: step 1, image 2 of 2
    • Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
  2. Yamaha NS-AW190BL Rear Casing Replacement: step 2, image 1 of 3 Yamaha NS-AW190BL Rear Casing Replacement: step 2, image 2 of 3 Yamaha NS-AW190BL Rear Casing Replacement: step 2, image 3 of 3
    • Crack open both parts of the casing carefully.
    • Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
  3. Yamaha NS-AW190BL Rear Casing Replacement: step 3, image 1 of 3 Yamaha NS-AW190BL Rear Casing Replacement: step 3, image 2 of 3 Yamaha NS-AW190BL Rear Casing Replacement: step 3, image 3 of 3
    • Remove the cooling foam.
    • Use a metal spudger to push the tab in on the red wire.
    • Repeat the process for the blue wire.
  4. Yamaha NS-AW190BL Rear Casing Replacement: step 4, image 1 of 2 Yamaha NS-AW190BL Rear Casing Replacement: step 4, image 2 of 2
    • The blue wire can now be removed from its connector.
    • Remove the red wire to free the rear casing.
Nick Ruiz
331 Reputation
3 Guides authored
USF Tampa, Team 17-3, Blackwell Spring 2017 Member of USF Tampa, Team 17-3, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 859
