Yuneec ST10 Plus Camera Switch Replacement
  1. Yuneec ST10 Plus Camera Switch Replacement, Battery: step 1, image 1 of 1
    • Flip the controller upside down to access the battery compartment.
    • Grab the compartment door and pull down.
  2. Yuneec ST10 Plus Camera Switch Replacement: step 2, image 1 of 1
    • Gently lift the blue tab connected to the battery in order to remove the battery from its housing.
  3. Yuneec ST10 Plus Camera Switch Replacement: step 3, image 1 of 3 Yuneec ST10 Plus Camera Switch Replacement: step 3, image 2 of 3 Yuneec ST10 Plus Camera Switch Replacement: step 3, image 3 of 3
    • To disconnect the battery from the remote, grab the red and black connectors.
    • Pull gently on connectors until they disconnect.
  4. Yuneec ST10 Plus Camera Switch Replacement, Camera Switch: step 4, image 1 of 3 Yuneec ST10 Plus Camera Switch Replacement, Camera Switch: step 4, image 2 of 3 Yuneec ST10 Plus Camera Switch Replacement, Camera Switch: step 4, image 3 of 3
    • Grab ahold of the top of the black cap on the button with the pliers and pull up forcefully.
  5. Yuneec ST10 Plus Camera Switch Replacement: step 5, image 1 of 2 Yuneec ST10 Plus Camera Switch Replacement: step 5, image 2 of 2
    • Twist counter clockwise on the silver portion of the device with a pair of pliers.
  6. Yuneec ST10 Plus Camera Switch Replacement: step 6, image 1 of 2 Yuneec ST10 Plus Camera Switch Replacement: step 6, image 2 of 2
    • Slide the Jimmy underneath the rubber grips and pry upwards.
    • With your free hand grasp the rubber grips and pull upward to remove it.
  7. Yuneec ST10 Plus Camera Switch Replacement: step 7, image 1 of 1
    • Remove the six 1.3 cm screws located on the back panel of the remote using the 5.5mm hex screw bit.
  8. Yuneec ST10 Plus Camera Switch Replacement: step 8, image 1 of 1
    • Remove the four 6mm screws from the handle using the 4mm hex driver bit.
  9. Yuneec ST10 Plus Camera Switch Replacement: step 9, image 1 of 2 Yuneec ST10 Plus Camera Switch Replacement: step 9, image 2 of 2
    • Carefully pull up and over on the back panel to remove. Take your time because there are wires connecting the two panels that can easily torn.
  10. Yuneec ST10 Plus Camera Switch Replacement: step 10, image 1 of 2 Yuneec ST10 Plus Camera Switch Replacement: step 10, image 2 of 2
    • Flip your device.
    • Once the silver cover holding the switch in place is removed, remove the switch by grabbing it and pulling back towards you.
  11. Yuneec ST10 Plus Camera Switch Replacement: step 11, image 1 of 3 Yuneec ST10 Plus Camera Switch Replacement: step 11, image 2 of 3 Yuneec ST10 Plus Camera Switch Replacement: step 11, image 3 of 3
    • Once the switch is removed, disconnect the switch from the circuit board by pulling the cable from the cable connector.
    • The cable will come out by pulling it away from you if the bottom of the controller is oriented closer to you.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 128
