Yuneec ST16S Cooling Fan Replacement
  1. Yuneec ST16S Cooling Fan Replacement, Battery: step 1, image 1 of 1
    • Hold down the button located above the battery while applying downward pressure to the battery.
  2. Yuneec ST16S Cooling Fan Replacement: step 2, image 1 of 2 Yuneec ST16S Cooling Fan Replacement: step 2, image 2 of 2
    • While still holding down the button, slide the battery out of its slot.
  3. Yuneec ST16S Cooling Fan Replacement, Backplate: step 3, image 1 of 1
    • Remove the single screw from the battery compartment.
  4. Yuneec ST16S Cooling Fan Replacement: step 4, image 1 of 2 Yuneec ST16S Cooling Fan Replacement: step 4, image 2 of 2
    • Remove the rubber bumpers from the back of the device using a spudger.
  5. Yuneec ST16S Cooling Fan Replacement: step 5, image 1 of 2 Yuneec ST16S Cooling Fan Replacement: step 5, image 2 of 2
    • Remove the two screws located under each of the rubber bumpers.
  6. Yuneec ST16S Cooling Fan Replacement: step 6, image 1 of 3 Yuneec ST16S Cooling Fan Replacement: step 6, image 2 of 3 Yuneec ST16S Cooling Fan Replacement: step 6, image 3 of 3
    • Remove the three screws along the top of the device.
  7. Yuneec ST16S Cooling Fan Replacement: step 7, image 1 of 2 Yuneec ST16S Cooling Fan Replacement: step 7, image 2 of 2
    • Carefully remove the backplate from the device.
  8. Yuneec ST16S Cooling Fan Replacement, Cooling Fan: step 8, image 1 of 2 Yuneec ST16S Cooling Fan Replacement, Cooling Fan: step 8, image 2 of 2
    • Remove the screws from the metal bracket and around the cooling fan.
  9. Yuneec ST16S Cooling Fan Replacement: step 9, image 1 of 1
    • Unplug the cooling fan from the device.
  10. Yuneec ST16S Cooling Fan Replacement: step 10, image 1 of 1
    • Remove the cooling fan from the device.
Christian Resendes
589 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 73
